finding my Gear Ratio ?????
Discussion in 'The Garage' started by gmcjimmy88, Mar 1, 2006.
  1. gmcjimmy88
    gmcjimmy88 1/2 ton status
    Feb 10, 2005
    559
    Fayetteville North Carolina
    I realize the best way to determine gear ratios is by removing the covers, but isnt there another way? I thought I read somewhere that you can rotate the yoke and count the axle spins to get a rough guess. This could be backwards or completely wrong that is why I am asking here. Is there a way to guestimate gear ratio without taking it apart? Something that could tell me a difference from say a 4:10 and a 5:13? I realize it wont be perfect unless the covers are removed but hoping I could get an idea before purchasing. Thanks for the help and hopefully answers to my questions.
  2. 1987Chevy
    1987Chevy Registered Member
    Jun 29, 2005
    51
    Connecticut
    If you have an accuate tach, and spedometer hooked up and know your trans gear ratio thirdgen.org has some calculators which I was able to use to be about 99% sure that I have good old 3.08 gears.:mad:
  3. gmcjimmy88
    Feb 10, 2005
    559
    Well I am purchasing rear diffs that are in a running truck. Thanks though
  4. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    pull the cover look for the marks on the ring gear.
    41 11 would be 41 teeth on the ring gear and 11 teeth on the pinion and a 3.73 ratio.
  5. Trigger Creep
    Trigger Creep Registered Member
    May 6, 2002
    28
    Bham, WA
  6. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    My way; both tires in the air. If the shaft is still attached, make a mark on it. Make a mark on the tire, or axle flange. Turn the shaft or yoke 1 complete rrevolution. Count how many times the tire rotates and multiply by 2. Its not very precise, but you will be able to tell the difference between a 3.07 and a 4.10.
  7. Dallin
    Dallin 1/2 ton status
    Feb 12, 2003
    135
    If it is an open differential:
    Jack up 1 tire (make sure other tire doesn't move)
    Spin the tire 2 complete revolutions (tranny in neutral if connected)
    Count the number of drive shaft revolutionsl. This is your gear ratio.
    3 & 3/4 revolutions = 3.73 gears
    4 & 1/8 revolutions = 4.11 gears
    If you mark lines on the tire and driveshaft you should be able to do this accurately enough to determine any gear size. Okay, you can't tell 4.10 from 4.11, but 3.73 from 3.40 is no problem.
  8. gmcjimmy88
    Feb 10, 2005
    559
    Those are the way I was thinking but wasnt sure. Thanks for the assistance. I will try it out on my truck here so I know what I am looking for up there thanks again.
