Finding TDC? brain fart
Discussion in 'The Garage' started by sled_dog, Aug 25, 2003.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    My friend and I are having brain farts. Working on the K5 and we can't remember to save our lives how to locate top dead center. Have the valve cover off and all I have to do is find TDC drop the distributor in, set the timing, and fire my K5 back to life!
  2. diesel4me
    Jul 24, 2003
    17,539
    923
    Massachussetts
    Take out #1 spark plug--put your thumb over the hole and crank it over in short bursts with a jumper on the solenoid,or with a helper if your lucky enough to have one--when the compression blows your thumb off the hole you know its on the compession stroke--Dont let the plug wire touch your thumb!! /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/angryfire.gifthen align the marks on the harmonic balancer with the 0 or TDC mark--set your distributor in with rotor at #1 position,being careful to make sure the oil pump drive goes in all the way and it sits flush with the intake--that should let it start--but if your like me the distributor will have to moved a few times a tooth either way to get it perfect.Havent got one right on the very first try in 20 years! /forums/images/graemlins/angryfire.gif
  3. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    You are looking for TDC on the compression stroke. To find it, align the timing marks on the balancer with both valves on the #1 cylinder closed. You can easily get the distributer in 180 degrees out by installing it with #1 at the top of its exaust stroke (you can tell because the exaust valve will be open with the piston all the way up)
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    yeah we finally got it, right after I posted my dad showed up at the house and helped us out. I didn't call him cause I knew him he wouldn't understand what I was asking and wouldn't be able to explain when he finally got it.
