Finding the gear ratio on a D60 rear?
Discussion in 'The Garage' started by 72Blazerod, Jan 11, 2003.
  1. 72Blazerod
    72Blazerod 1/2 ton status
    May 18, 2000
    264
    Vancouver, British Columbia, Canada
    Is there any way to tell the gear ratio on a Dana 60 (rear) without popping the diff cover or spinning the tires? I have one on my garage floor right now and I want to sell it but I need to know the gear ratio for the ad. Thanks!
    Rod /forums/images/graemlins/k5.gif
  2. K5Dan
    K5Dan 1/2 ton status
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    unless it has some kind of tag on it i don't think so .your probably going to have to pop the cover off.
  3. great scott
    great scott 1/2 ton status
    Dec 31, 2002
    333
    Utah
    you can do the tire spining method even off the truck and it should get you close.
  4. 72Blazerod
    May 18, 2000
    264
    Right now it is flat on the floor with no wheels or tires on it. It is just too heavy to try and spin the axles. Do you guys know where the tag would be on this thing? I'll try to see it I can find that and read it. Thanks again!
    /forums/images/graemlins/thumb.gifRod
  5. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Dana's will have a tag. The Dana 60 I dug out of a '72 3/4-ton Longhorn had it. Was bolted on with one of the cover bolts.
    Of course, the last guy who changed the diff oil may have kept it as a momento /forums/images/graemlins/wink.gif
