Fine thread vs. course threads??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Eric M., Nov 2, 2002.
  1. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    I need to bolt on my rear spring perches (they got knocked off in an accident). I thought I'd purchased grade 8 fine threads, but when I got home, all I had were course threads. I've always heard that course have a tendancy to loosen on vehicles, is that true?
    I am using crush nuts and lock washers and was even thinking of Locktite as well.
    What is the real diference between course and fine threads?
    Thanks,
    Eric
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> You should get the fine threads, not only do they have less tendency to loosen, but you can put quite a bit more torque on them as well. </font color>
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    It's all a matter of surface area.
    Fine threads will have more contact with a thread than coarse thread.
    It will tolerate more torque.
    Get fine thread.
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    What the others said..... /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif
  5. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    I put all course thread on my truck grade 8 haven't broke any yet
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    It depends on the direction of the load. In a shear situation, a fine thread and coarse thread have pretty much the same strength. But in a tension situation, the fine thread bolt has a much higher load rating. A coarse thread will fail much earlier due to the reduced surface contact area between the two parts. An excellent example is the 6 tiny studs that hold the spindle to the steering knuckle. They see tension loading, since the spindle fits too tightly into the knuckle to allow much shear load. They're grade 8, fine thread. /forums/images/graemlins/cool.gif
    Also think about the splines on an axle or transmission shaft. They're loaded in a shear direction. Yet the big, beefy looking splines on the output shaft of a 10-spline 465 tranny will fail long before those tiny looking splines on a 32-spline Turbo 400 output shaft.
  7. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    all i use is grade 8 fine thread or grade 5 fine thread. if i am not mistaken you can only get grade 8 in fine thread!?!
    i dunno, maybe i am wrong.
    everybody has said the right stuff on the surface area and more TQ on them. they are all right on that. i would go with fine thread. 8 or 5 is good in the case of bolting to your frame. from what i understand your frame is about = to grade 5. 8 can be pulled through damaging your frame. i still use 8 though.
    Grant
  8. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Yes you are wrong but it's OK /forums/images/graemlins/grin.gif
    Grade 8 can come in either fine or coarse.
    I use some coarse for the spring eyes.
    Anyway, the arguments here on the fine versus coarse are close but no Cigars.
    The contact area is very close so this is not the reason.
    The strength issue is actually the opposite, fine thread has less depth and can strip easier, but if you look or think about the angles of a fine thread v/s a coarse, the fine thread doesn't loosen up as easily because the slopes are close to flat, as opposed to the coarse which are sloped and it makes it easier for the nut to slide and release tension.
    And for the torque thing, if you torque them to the same torque reading you will get more tension on because it's much easier to turn in those shalow slopes. So be carefull when you torque down fine threads verus coarse.
    I hope I didn't go too scientific on you guys, but that is what a mechanical engineering course will do to you.
  9. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Coarse threads are:
    More readily available in industrial fasteners
    easier to assemble because of larger helix angle
    require fewer turns and reduce cross threading
    higher thread stripping strength per given length of thread
    less critical of tap drill size
    not as easily damaged in handling
    Their disadvantages are:
    lower tensile strength
    reduced vibrational resistance
    coarse adjustment
    Fine threads provide:
    higher tensile strength
    greater vibrational resistance
    finer adjustment
    easier cross threaded
    threads damaged more easily by handling
    tap drill size slightly more critical
    slightly lower thread stripping strength
    In your application, I would use coarse thread SAE Grade 8 fasteners with hardened nuts and hardened lock washers.
  10. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    That is put even better.
    And I forgot to give my recomendation, I second blazer1970's motion, go with coarse thread for the strength.
    Just make sure you use lock nuts, the crushed style not nylocks.
  11. hammer
    Aug 29, 2001
    449
    Binghamton N.Y.
    checked a ref machinery book and fine thread is 9% stronger than course. By torque specs
