Finished Echobit flip, now front sits way too low.
Discussion in 'The Garage' started by MudFrog, Feb 23, 2005.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Before I did my flip my front bumper was 27" from the ground and the rear was around 29" from the ground (4" block). Well after finishing the flip my front sit's 25.75" and the rear sits 32" off the ground. Needless to say my truck is sloping down :blush: . I have some pretty old 4" superlift softride springs in the front and I'm sure they sag a bit.
    Soo... I need to semi level this thing out and I kinda doubt the 1" zero rate will fulfill my quest. I think I'm going to have to bite the bullet and buy some new 6" springs. Anyway I guess my question is has anyone run into this and if so how did you fix it? I know the more lift I add in the front the lower the rear will become but I just don't think 1" will do it. Thoughts?
    On another note, the blazer rides awesome now. Nice and smooth. No more terrible axle wrap when I hit the gas.
    Scott
  2. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    If you wanted to do the 52" swap it would help, i have a ORD flip and zero rate in the back of mine, when i did the 52s i had a zero under them that had to come out because the truck was pointing up, after pulling it she sits level, so i guess that i got around 5"s of lift out of them, if yours are sagging you may get up to two inches of lift over what you have now and a zero rate could always go in if its still a little low
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Do you run the top or carry anything ? Maybe your front springs are really tired . I have the Echobit flip , 4 inch springs which are now 1 year old , and I barely sit up in the rear , you can notice , but it looks sweet . Had my top off a few weeks ago , and she didn't sit too high . Each truck is different , but I'd think your front springs need replacing . Maybe flip the brackets around , get used 56's for the rear , and she will probably come down a bit :k5: :k5:
  4. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    This is with the top on and some stuff in the back, mabye 50 lbs worth of stuff. In the past when I put my soft top up it raises even more.
    Can you get 4" springs rearched or do you need to replace them?
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If there is a spring shop in your area , sure . If not , weigh the shipping price and work and decide what to do :k5: :k5:
  6. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    :blush:
    I hear ya
    :rotfl:
  7. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Haha... I'll have to take a picture of mine.
