Finished Engine (pics)
Discussion in 'The Garage' started by muscle, Apr 20, 2005.
  1. muscle
    muscle 1/2 ton status
    May 28, 2000
    408
    Show Low, AZ
    Built up a nice 400 small block.
    Balanced crank and rods.
    High vol oil pump.
    dual roller timing chain.
    9 1/2 to 1 Speed-Pro Hypereutectic Pistons
    Comp cams 444 lift/ 214, 214
    comp cams roller tip rocker arms
    stock heads port matched, polished and pocketed 1.94 intake/ 1.75 exhaust.
    new accell HEI distributor.
    Weiand 8004 intake
    Holley 750 cfm carb.
    flowmaster headers.
    Also
    140 amp alternator ( had to fabricate custom bracket )
    AC compressor for occassional air.
    we estimate this to be fairly peppy at 360 - 375 hp but runs on pump gas. Not sure as to the torque spec.
    I mocked up alot of accessories to be sure of fit but I plan to stab her with headers, starter, powersteering pump attached as well as all bracketry.
    enjoy :D
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    nice engine
  3. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    Sweet!
  4. Ryan B.
    Jul 18, 2001
    5,693
    CA
    nice.
    you'll dig those stage 8 locking header bolts.
    i think those heads will eventually rust if not painted.
  5. muscle
    May 28, 2000
    408
    Show Low, AZ
    we'll see how the unpainted heads do. I think it looks tough with the two tone effect. spray'em down with some WD-40 or something
  6. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Look good I like your bracket I would paint those heads silver though... it will match the intake and not rust
  7. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Are you doing the CS-140 alternator upgrade with this? I picked up the adapter pig tail today and plan the swap myself.
  8. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    Looks good. :D
    I bet it will last longer than my 400 did.
  9. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    That's beautiful, nice work!
  10. muscle
    May 28, 2000
    408
    Show Low, AZ
    the alternator is a Delco 140 AMP part number 7157. Its housing is much larger at almost 7 inches in diameter, thus the custom bracket. I fried my stock alternator about a year and a half ago on a long winch pull using my warn 8274. My rig will have the dual battery setup with isolator and ambulance style battery rotary switch in the cab. The larger alternator will take alot more abuse.
  11. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    A fresh motor is always a treat. Good job, brother!!!
  12. nc87k5
    nc87k5 3/4 ton status
    Sep 23, 2003
    5,231
    North Carolina
    nice!!! I love Chevy orange.
  13. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    do you meen like on board air i see some copper lines ?
  14. muscle
    May 28, 2000
    408
    Show Low, AZ
    Yes, sorry it is for on board air. The ac compressor I dont think was meant for any continous duty but is good for filling up a tire. I tried to fill up an air mattress with it once and smoked it pretty good. You need to be able to have a port in the air intake where you can add some oil periodically as well.
  15. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    That's a purdy motor.
  16. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    If ya want to stay with the cast look there is an engine paint called cast back.
    It looks just like a fresh cast surface and is an engine paint.
  17. dyeager535
    26,982
    191
    Some of the engine pics here will show you what your heads will look like in a month or so.
    3 pages of pics
  18. 1985K20
    1985K20 1/2 ton status
    Jan 11, 2005
    191
    Quebec,Canada
    Where's your high-volume Fuel pump ;)
  19. muscle
    May 28, 2000
    408
    Show Low, AZ
    Thanks for all the comments guys I appreciate it. I may have to mask off some things and paint those heads. Black or something. anyways I cant wait to get the rest of the truck together and fire her up. :cool1: :cool1: :cool1:
  20. SUPER'BURB
    SUPER'BURB 1/2 ton status
    Jan 9, 2005
    929
    Mountain House, Ca.
    I'd clear coat those heads but you are right
    IT LOOKS COOL!!! :saweet:
