Finished my front inner fender triming
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CK5, Sep 27, 2001.
  1. CK5
    May 19, 1999
    21,622
    701
    CO
    This past weekend I cut my front inner fenders up higher and pounded the cab lip flat for more tire clearance, the 37's were still hitting, when they hit now they will have a flat surface to rub on. I will post the pics tonight if anyone wants to see them.
    PS - This is what started all the fender trim talk, it happens every time I break out the sawzall.
    Steve
    Bandwidth FREE ZONE
    Mall-Running poseur 4x4 with curb-feelers
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Cool, I too am doing the trim up. My 35s hit front and rear when I was crawlin the riverbed at FRains with GoldRush and FrizzelFry. I hear ya with the sawzall!! I have the drivers side cut still need to attack the pass side. I am removing my rockers and corners. I have one 3x3 square tube rock slider almost done too!!
    Good Luck
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
  3. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    The sawzall is about to meet my truck here pretty quick..heh, heh, heh..... &gt;:-)
    If you see my truck on a trailer, call 911 cause it's <font color=red>STOLEN!!!</font color=red>
    Website link is in my profile [​IMG]
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    Sounds like I did about the same thing. I cut my inner fenders up to right below the inner fender bolt against the firewall...
    Mike
    <font color=green>"My K5 is purdyr than your sister!"</font color=green>
    <a target="_blank" href=http://www.geocities.com/emmettology101>www.geocities.com/emmettology101</a>
  5. CK5
    May 19, 1999
    21,622
    701
    CO
    There are and upper and a lower fender bolt right next to the outer fender, I just cut below the upper one cutting the lower off completly, still feels solid.
    Steve
    Bandwidth FREE ZONE
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    Oooppsss... I cut right below the upper mount.. The one that usually rots out!
    Mike
  7. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    That's where I cut mine out. No worries about them holding together, but I've still got to finish welding my fenders on the inside to give them a little more strength. I've thought a little about moving the innerfender up a little in the wheel well to give myself just a little more up room. Did you move your front axle forward any? I have no rubbing wih the 36" I'm running, Maybe you just flex a lot harder than me. The SSR's come in at about 36.5 right? I guess the extra little bit is the difference, my 36's measure a good 35 or so. That may be the deal. I'm pretty sure when I go up with the boggers I'll get a little rub, guess I'll just have to call Alcan and get those new longer springs after all and move the front tire forward a bunch [​IMG]
    Kyle
    89K5
  8. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  9. CK5
    May 19, 1999
    21,622
    701
    CO
    Axle is still in the stock location, but I plan on going with some Alcan's and I will relocated the centerpin forward by an 1" to 1-1/2" or so. Someday she may be wearing 39.5's so migh as well look at it now.
    Steve
    Bandwidth FREE ZONE
  10. Grim-Reaper
    7,385
    Atlanta
    I'm looking at a set of pin relocaters now. Good for 3/4 to 1/2 an inch but since I'm still with a normal drag ling I'll have to shorten it by about 1/2 an inch. communities.msn.com/OffroadK5s
    75 Jimmy, Dollar
    Grim-Reaper
  11. Grim-Reaper
    7,385
    Atlanta
    I'm looking at a set of pin relocaters now. Good for 3/4 to 1/2 an inch but since I'm still with a normal drag link I'll have to shorten it by about 1/2 an inch. communities.msn.com/OffroadK5s
    75 Jimmy, Dollar
    Grim-Reaper
  12. CK5
    May 19, 1999
    21,622
    701
    CO
    ORD makes them too, thats how I got my rear axle back 1-3/4" you can run them on the front as well, Just an add-a-leaf with an offset pin.
    Steve
    Bandwidth FREE ZONE
  13. Grim-Reaper
    7,385
    Atlanta
    These are just a plate the size of a spring purch. I'm plenty stiff up front already [​IMG]
    I don't need no damn shop manual, I got a pornographic memory.
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
    75 Jimmy, Dollar
    Grim-Reaper
  14. RGF
    RGF 1/2 ton status
    Jan 5, 2001
    281
    Maine
    I cut the upper bolt off the firewall and angle cut that seam to gain an extra inch so I could lay the inner back more.
    Also by the inside bolt(the one with the big washer) I cut it so everything would lay back, then reshaped and welded.
    RGF
  15. CK5
    May 19, 1999
    21,622
    701
    CO
    Any pics of your rig RGF?
    Steve
    Bandwidth FREE ZONE
  16. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    What RFG said, been like that for about a year now. I got no more room unless I want to move the floor pans in some. My only option is go relocate the axle forward if I go to bigger tires.
    I can take some shots of mine in the A.M. and email them to ya if you want.
    Depdog
    <font color=blue>Weenie K5, little mods' Small Tires!</font color=blue>
    <a target="_blank" href=http://depdogsk5.coloradok5.com>depdogsk5.coloradok5.com</a>
  17. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Cann't wait to see Steve.... I need to trim mine more too... cann't wait to get mine finished......
    C'moe
    Kill Roy was here!
  18. bigk
    bigk 1/2 ton status
    Jun 13, 2001
    358
    Mendon Illinois
    How much do you have to jack with the steering if you move the axle forward?
    Karl
    Temporarily Unemployed Underwear Model
    87 3/4 ton
  19. coloradoblazers
    coloradoblazers 1/2 ton status Premium Member
    Mar 2, 2001
    506
    WY
    When i trimmed, I cut the body and just used a bmfh to pound the fenders back. I left enough of the body that I was able to bend it to meet the inner fenders and screw them togeather. TO help w/ rust I put on a finishing layer of bond-hair, covered it up w/ new paint. Doesn't look half bad.
    K5- because size DOES matter!
    Fear This
  20. twenty_below0
    twenty_below0 1/2 ton status
    May 16, 2001
    436
    Haines, Alaska ...u.s.
    yeah I am also interested in the details of exactly what it takes to move the axle forward...will make a post about it!! all info needed THX.
