Finished sliders and cool custom steps! Well almost. What to you think?
Discussion in 'The Garage' started by mrk5, Jun 11, 2004.
  1. mrk5
    Apr 20, 2004
    12,341
    1,047
    Northern Colorado
    Finish my steps and sliders. What do you all think?
    Gotta do final clean-up and paint them yet. Can't decide if I want to do yellow matching the truck or black.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Re: Finished sliders and steps! Well almost. What to you think?
    I like it alot , good work. /forums/images/graemlins/waytogo.gif Are planning on removing the step before wheeling ? Love the logos and cut out k5 /forums/images/graemlins/thumb.gif
  3. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    looks good. do you have any pic's to show how there mounted.
  4. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    It took me a minute to realize you cut the "k5" into the steps, I thought it was a sticker for a minute /forums/images/graemlins/doah.gif
    Looks good, how thick is the mounting part? Will it hold up to someone standing on it? /forums/images/graemlins/waytogo.gif
  5. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    looks good... maybe make some quick release mechanism so you can remove them when you go wheelin.... /forums/images/graemlins/thumb.gif
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    A couple ideas just popped in my head . How about some pins like on the swaybar disco's . Or just tap the slider, or weld the nut on behind it, and unbolt it as need it . I like the quickpin idea /forums/images/graemlins/k5.gif
  7. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    yea that would work.... would the pin hold it tight enough so it wasnt rattlin around, and when you step on it, it wont bend?
    The bolt idea maybe the way to go...
  8. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    Ditto /forums/images/graemlins/whistling.gif
  9. mrk5
    Apr 20, 2004
    12,341
    1,047
    Northern Colorado
    If you look closely at the top view of the step you can see the two bolt heads. I welded nuts on the backside of the tube. That way I just get out the rachet and unbolt them.
    I had contemplated the pin idea. But as already stated, I didn't think I could keep them from rattling.
    I weigh 280 /forums/images/graemlins/ignore.gif and they don't give a bit. They are made with 1/4" aluminum plate side peices with the bowtie and "K5" engraved 1/8" into them. The foot pad is also 1/4" aluminum plate with the bowties raised .090" and the K5 cut out. For support undet the foot pad there is 1" aluminum tube across the front and 1" aluminum across the back.
  10. mrk5
    Apr 20, 2004
    12,341
    1,047
    Northern Colorado
    Let me know of any other pics/angles you'd like to see.
  11. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    what I ment was how are the sliders mounted to the truck. I like that idea of using that step on the sliders.
  12. mrk5
    Apr 20, 2004
    12,341
    1,047
    Northern Colorado
    I wondered if that was what you meant.
    The sliders themselves are 2"x3"x1/4" tube. I welded 4" c-channel to them and bolted them to the cross supports that support the floor. I'll see about getting pics if you are still interested.
  13. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    I should have said that in my firts post. don't wory about the pictures I thouht maybe you had mounted them to the frame. question when you mounted the c-channel to cross sopports how many bolts did you use? and are you going to add kick outs?
  14. mrk5
    Apr 20, 2004
    12,341
    1,047
    Northern Colorado
    I used three 7/16" bolts on each brace (2 per slider).
    I modeled the mounting from the review I read on this site of the 4x4 Iron sliders. When they first installed them there were no braces back to the frame, and they said the sliders still stood up to some impacts.
    To be honest I don't do extreme wheelin' so I figure what I've done will be enough. Really the sliders were just a good way to mount the steps that would also serve some function.
  15. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    sounds good, I was thinking using 2x4 square tubing for the slider and mounting it the way you did. I don't really do hardcore stuff either but when you wheel a sub I got to have some body armor.
  16. mrk5
    Apr 20, 2004
    12,341
    1,047
    Northern Colorado
    Yeah, I was thinking after I had them installed them that 2"x4" would would give better protection.
  17. mrk5
    Apr 20, 2004
    12,341
    1,047
    Northern Colorado
    ttt /forums/images/graemlins/whistling.gif /forums/images/graemlins/rolleyes.gif
