Finished the 90K5 Headlight Relay Modification
Discussion in 'The Garage' started by DPI, Jul 30, 2002.
  1. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    This is a pretty straight forward mod. I replaced all wire from the relay to the lights, the ground wires, and the power wires with 10 guage fine strand. Here is the final wiring diagram for a 1990 K5. Not sure if prior years are the same, but years after should be. This mod really makes the factory headlights much brighter. This is due to connecting directly to the alternator or battery through the relays and not going through the high guage (low amperage) factory wire.
  2. MUDNUTT
    MUDNUTT 1/2 ton status
    Aug 1, 2001
    339
    Mn
    if i picked up some relays would this work on my 79?
    deck
  3. GRINCH
    GRINCH 1/2 ton status
    Jan 30, 2001
    1,951
    Helena, MT
    Nice post... Steve should put this in the techie articles..
    Will be doing it also.
  4. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Yeah this should work for you, if you have 4 headlights. If you only have the two, just use the low beam portion of the diagram only. You will notice a big difference in brightness.
  5. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Thanks, If he wants to put it in the techie section, that would be OK with me. The hardest part of this was pulling out the old wires running under the radiator and re-running the 10 guage wires in their place. I wanted to install the new wires as "factory" as possible. Other than that is was a piece of cake.
  6. bigjbear
    Feb 18, 2000
    13,971
    451
    Marietta GA
    Cool, I was thinking about this after I installed a set of aux lights w/ a relay. Compared to others I had done w/o a relay set up they work better/brighter. Plus my headlight wiring has been hacked and spliced already.
  7. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    I forgot to mention, the third relay closest to the bottom of the diagram keeps the low beams on while the high beams are on. This is basically the same set-up as the PainLessWiring mod.
  8. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Here is a pic of where I mounted the relays. Behind the aux. battery.
  9. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    What rating are the relays?
  10. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    Wow! Great post! /forums/images/icons/cool.gif /forums/images/icons/cool.gif /forums/images/icons/cool.gif
    *Ski adds another mod to list* /forums/images/icons/smirk.gif
  11. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    They are 30 Amp relays.
  12. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Actually, you still need 2 relays even with a 2 headlight system. Each lamp in the 2-light system has dual filaments, with a common ground. Connect the low-beam part of the circuit to the low beam filaments and the high beam part of the circuit to the high beam filaments. /forums/images/icons/cool.gif
  13. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Thanks for the clarification!
    dp
  14. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Okay, so I'll need the wire, the relays, 30 amp fuses? Can I get new connectors for the headlights from the parts store? Then wire everything from the lights into the alternator, then another wire to the battery? I'm thinking about doing this on my '87. Should be the same, right?
  15. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    The only difference on an '87 will be if you have the over/under headlights. With that setup, all 4 lights are on in high beam mode. The upper lights have dual filaments. The high-beam wiring, right at the headlights, probably already has the high beam filament in the upper lights tied to the lower lights, which are high beam only. Just be sure that you keep them tied together so all of the high beams will be going through the relay. /forums/images/icons/cool.gif
  16. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Yeah, what Harry said. You can tie into your existing connector as close to the connector as you can, not sure if a parts store would have a new one, but the old one should work. The 89-91 K5s use a different style connector, it is basically a female splade. The wire from the alternator to the battery is not really necessary. The alternator should be feeding your lights. You should have an 8 guage wire already there. On mine, I did run another wire to the battery. I used a 4 guage. But I am running a dual battery setup and a winch and all that is charged through that 4 guage wire, so I wanted it large enough to handle the juice.
  17. 91GMCSuburban
    91GMCSuburban 1/2 ton status
    Dec 9, 2002
    318
    San Antonio, TX
    worth reviewing
  18. ZooMad75
    ZooMad75 1/2 ton status Premium Member GMOTM Winner
    Apr 5, 2003
    1,006
    609
    Pueblo, CO
    Thanks DP 90K5! I was planning on doing this, just needed to figure out the wiring and you've don't it for me. SWEET! Of too the parts store for some 30 amp relays, wire and shrink tubing!!! What did the 30 amp relays cost you?
  19. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Man, I am surprised this is still around.
    I bought my relays and plugs here .
    They have excellent pricing and service!
  20. 91GMCSuburban
    Dec 9, 2002
    318
    San Antonio, TX
    got part numbers?
