Finished the Swap.. Having Problems!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SAVAGE1, Sep 1, 2001.
  1. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    I just completed my 3/4 ton swap. The rear is a 14BFF with 4.10's and the front is a D44 with 4.09's. The axles came from different trucks. My problem is when I stick it in 4-H and 4-L, I roll at idle for about 15 feet and the transfer case seems to bind up and the truck stops. This is only at idle speed but when I give it some gas I hear some tire chirping and the truck starts to bounce a little. It feels like I have totally different gear ratios in my axles. So I re-checked the numbers stamped on the ring gear: Rear is 41/10=4.10, Front is 45/11=4.09. What gives? I'm out of ideas. Please help!!
    Truck Specs: 85K5 350 700r4 np208
    Rod
    Alameda, CA
    85 K5 6"ProComp 35"Boggers... and it's still not BIG ENOUGH!!
    <a target="_blank" href=http://coloradok5.com/gallery/K5Jungle>http://coloradok5.com/gallery/K5Jungle</a>
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>The fronts were always geared slightly lower than the rear. This was so the front tires would pull instead of getting pushed by the rear.
  3. SAVAGE1
    May 22, 2000
    1,104
    BAY AREA, CA
    Yeah but is it normal for the truck to start hopping and tire chirping? And it won't cruise at idle speed. It stops after a couple feet.
    Rod
    Alameda, CA
  4. Gold Rush
    Gold Rush 1/2 ton status
    1,498
    Rod,
    First double check everything again. Are U-joints together right, pinion angles not to much, T-case linkage not bent, etc. Could your t-case shifter be sticking and not putting the case all the way into 4wd? Maybe your t-case is shot? How about putting the truck on 4 jack stands and spining each tire 5-10 times to see if you hear any noises? Let me know after trying these things what you find.
    David
    <a target="_blank" href=http://www.extremeblazer.com>http://www.extremeblazer.com</a>
  5. SAVAGE1
    May 22, 2000
    1,104
    BAY AREA, CA
    David, I'll check that stuff in the morning. The truck drives fine in 2wd. Right before I did the swap I blew my 10 bolt. I was flexed up pretty good and I gassed it then *BANG*. If the transfer case went bad what part should I look at. Thanks for the help.
    Rod
    Alameda, CA
  6. K5RON
    K5RON 1/2 ton status
    Apr 14, 2001
    219
    This might be stretching it a bit but what's the possiblity that the front is in high and the rear in low or vice/versa? Don't know if this could happen with a chain drive but it's possible with a worn set of shifter interlocks in a NP205.
    Ron
  7. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    41/10 IS 3.73 not 4.11!!!!!!!!!!!!!!!!!!!!!!!!!!!!! your doing DAMAGE
    88k5 silverado w4"lift <font color=orange>d44 and corp14ff</font color=orange> with 4.56s
  8. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Last time I checked 41 divided by 10 is 4.1
    You might want to check your math or use a calc.
    86 Jimmy 4"lift 35"MTRs Other cars 69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  9. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
  10. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    yeAH coopertwpk ISN'T THE SHARPEST KNIFE IN THE DRAWER ...hehe
    Surfing is Life...
  11. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    This may be a stupid question...are you trying out 4 HI and 4 LO on dry pavement? It sure sounds like drivetrain wind-up to me...
    The slight ratio differences and whatever inhereant differences in tire diameter and air pressure will be enough to cause strain in the drivetrain even in a straight line. And yes 10 to 15 feet would be all it takes. I can get the same results in my truck and the ratios are 3.73 front and rear...
    Rene
  12. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Kind of a sanity check, but maybe count the R&amp;P teeth in both axles to make sure what's stamped is really what's there??
    <a target="_blank" href=http://coloradok5.com/gallery/75K5>http://coloradok5.com/gallery/75K5</a>
  13. SAVAGE1
    May 22, 2000
    1,104
    BAY AREA, CA
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    Rene, It was on dry pavement. So you think its normal? I'll check everything else mentioned.
    Thanks guys.
    Rod
    Alameda, CA
  14. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Yes it is normal...
    Take it out on some gravel or dirt road and try it out.
    Never drive in 4 hi or 4 lo on dry pavement...the front and rear is locked together and you could damage the drivetrain.
    Rene
  15. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I agree with trusty. Put it up blocks and check it out. Or try it out on some dirt...DAN
    If it ain't broke.......Don't fix it....
    <a target="_blank" href=http://coloradok5.com/gallery/Gokartergo>KLICK</a>
  16. redbeast
    redbeast Registered Member
    Dec 23, 2000
    67
    San Marcos Texas
    Im have driven mine in 4hi on pavment before ,not very far or very long, but I dont remember any binding or popping ???? ..My diff is open in frount and a eaton gov lock in the rear with 3.43s.........
    1985 Blazer, 305 soon to be a TBI 350, 700r4, msd ign, 3.43s, headers, 31x10.50x15s
  17. coopertwpk
    Mar 18, 2000
    478
    Ok my front is a 44 and the rear is a 14 the count on factory gears is 41/11 which is 3.72 now why dont you guys <font color=red>smell some pretty flowers (offensive statement removed)</font color=red> go count your gears and the 44 I have has 45/11 now thats 4/09 now isnt that just funny that he has special count gears and im screwed and have to regear my rear end.
    <font color=red>uhhhh lets be a little less hostile. you made a math error and going off on others that were pretty civil in pointing out the error was childish.
    Grim</font color=red>
    88k5 silverado w4"lift <font color=orange>d44 and corp14ff</font color=orange> with 4.56s<P ID="edit"><FONT class="small">Edited by Grim-Reaper on 09/03/01 03:32 PM.</FONT></P>
  18. SAVAGE1
    May 22, 2000
    1,104
    BAY AREA, CA
    &lt;blockquote&gt;&lt;font class=&amp;quot;small&amp;quot;&gt;In reply to:&lt;/font&gt;&lt;hr&gt;&lt;p&gt;Ok my front is a 44 and the rear is a 14 the count on factory gears is 41/11 which is 3.72 now why dont you guys <font color=red>smell some pretty flowers</font color=red> and go count your gears
    <hr></blockquote>
    Where did you get "41/11". Scroll up to my original post. I never said 41/11... it is 41/10 which equals 4.10.
    Anyway, I had the truck up on jacks and checked everything out... and it looks fine. With my 10 bolts I could drive on dry pavement with no problems, that's why I was concerned with the binding problem with the new axles. Anybody else have some input on this. If its just a normal thing I guess I'll just live with it. I just don't want to blow up my Tcase.
    Thanks again guys
    Rod
    Alameda, CA
    &lt;a target=&amp;quot;_blank&amp;quot; href=http://coloradok5.com/gallery/K5Jungle&gt;http://coloradok5.com/gallery/K5Jungle&lt;/a&gt;<P ID="edit"><FONT class="small">Edited by Grim-Reaper on 09/03/01 03:36 PM.</FONT></P>
  19. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    first off, relax a little. this is quoted directly from your earlier post.
    <hr></blockquote>
    If it was just a typing error then sh!t happens, but 41 divided by 10 is 4.10...
    Rene
  20. K5RON
    Apr 14, 2001
    219
    Ok my front is a 44 and the rear is a 14 the count on factory gears is 41/11 which is 3.72 now why dont you guys <font color=red>smell some pretty flowers</font color=red> and go count your gears and the 44 I have has 45/11 now thats 4/09 now isnt that just funny that he has special count gears and im screwed and have to regear my rear end.
    88k5 silverado w4"lift d44 and corp14ff with 4.56s
    Little more fuel---------------Your sig says you have 4.56's! Was up wit dat?
    Ron<P ID="edit"><FONT class="small">Edited by Grim-Reaper on 09/03/01 03:37 PM.</FONT></P>
