FINISHED WITH PIX missouri off road outfitters shock mounts???*PIX*
Discussion in 'The Garage' started by down4thakrown, Jul 9, 2005.
  1. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    will i have to grind off the factory bump stops? could i use 1 existing hole to line it up?
  2. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    I just left mine on.
    -Harrison
  3. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    what did you use to allign the axle mounts with the x member
  4. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    well after reading the instructions for a second time i found out the axle shock bolts are suppose to face the rear of the truck,not the ones on the xmember. :doah: so i cant use an existing hole. :doah: but what's a good tool to allign the axle mounts with the xmember mounts??
  5. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    i used a long level off the side of the axle shock mount to the out side of the frame and made my marks.
  6. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    got it in there but one shock is compressed about 1/4inch more then the other :confused: i checked the top and bottom mounts and every thing measures out even? is this normal
  7. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    here are the pix
    the one on the right is compressed more then the one on the left????
  8. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I bet the install was pretty easy. Don't forget to cut off all that extra thread everywhere. Are you going to have to change shocks? They look too long in the pictures.
  9. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    hardest part was lining up the bottom mounts with the top.i'll probably end up buying new shox but that would be after i take it on a ramp or somthing to flex it out and see how much further it needs to go and if my drive line will clear the xmember.
  10. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    Yeh..the shocks do look a tad long for that application.........
    I hope he got a deal on those blemished (factory reject) tires
  11. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    the rear end might be goin up some, im bout to switch the shackles around. this might give me an 1" but they'll probably still be too long.
