Finishin Up my '88 350 Rebuild, got a few ?'s
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Indy, Dec 16, 2002.
  1. Indy
    Indy Registered Member
    Nov 18, 2002
    6
    Reno, Nevada
    Finishin Up my \'88 350 Rebuild, got a few ?\'s
    Just rebuilt my centerbolt 350, and I have a few questions. I have one nipple on the intake manifold that I can't remember where it goes. It's between the EGR valve and the HEI coil. This is an '88 TBI. Also, does anyone offer shorty headers for this year K5 with AIR? Wanted Edelbrock, but can't find any shorties. Thanks, guys!-Indy
  2. GOK5
    GOK5 Registered Member
    Aug 19, 2002
    23
    wandering aimlessly about
    Re: Finishin Up my \'88 350 Rebuild, got a few ?\'s
    Check out JBA headers. They make shorties for 87-91's
  3. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    If you change the exhaust make sure you instal an O2 sensor.
    John
  4. dyeager535
    26,979
    If you have to change the exhaust, is there any reason to go with shorties?
    Not saying shortiesare bad, but I just saw it mentioned in an article somewhere that the shorties made less power. Of course, the comment was made in passing, so no hard numbers, just that they weren't as "efficient".
  5. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    The extra vacuum port should go to the brake booster, I think.
  6. Sidepipes
    Sidepipes 1/2 ton status
    Nov 9, 2002
    139
    St. Thomas, Ontario, Canada
    it should definitely go to the brake booster but many vehicles had it tee off to feed other things too, if the fitting only has one plug you know it goes to the brakes if there are more..... ya better start looking for where it goes.... If you need help, my 86 has an 89 TBI engine in it, I can take a peak and see if it goes anywhere else.
