Finishing up my lift - options?
Discussion in 'The Garage' started by Scrubby, Jul 26, 2004.
  1. Scrubby
    Scrubby 1/2 ton status
    Dec 1, 2001
    114
    Boise, ID
    This weekend I installed a 4" tough country lift on my '72 K5. It is all on there, and I like the way it looks, but I have the following problems now:
    1) Both my front and rear drivelines are too short. They almost bolt into the yoke, but are about 1/2 inch too short at full extension. Can I make this up by lowering the transfer case, or should I just go to a driveline shop and get these extended?
    2) Need new brake hoses. I have been reading the ongoing threads about the hoses from napa. Since I have a D44 upfront, I think I am going to go with some braided lines instead of modifying the napa hoses.
    3) My e-brake cables are too short now. I can get them to connect back up, but they rub against the rear spring a bit. What are my options here? Just lose the e-brake? Move the brackets on the frame down a bit?
    Any suggestions?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    You may want to lengthen the shafts if they are already extended and don't fit , so you don't push them through your transfercase . I have six months on stainless hoses and no problems yet . I have seen some pics of a member here who lowered their e-brake brackets with good sucess on a second gen , could possibly work on yours if its simillar . /forums/images/graemlins/k5.gif
  3. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    the only thing I can tell you is about #1 I would get new drive shafts even if you drop the tcase youll still only have and inch to play w/
