Finishing Up The Truck - All The Small Little Wrap Up Things - With Pics
Discussion in 'The Garage' started by Resurrection_Joe, Apr 30, 2004.
  1. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Ok, I just shaved and threw the 14BFF in yesterday and today along with new rear springs, so I have very minor things left to do on the truck. I know most of them, because they are individual projects, but there has to be a lot of generally universal things I am forgetting.
    Ok here's the few projects I need to get done (not coutning major fab work)
    Rear U Joint
    Front Shocks
    Tourque Everything Down
    Wire In Winch
    Fill All Fluids
    Bleed Brakes
    Bolt Up Front Shaft
    Wire In Fuel Gauge
    Front Hub Install
    The Fluids I Can Think Of Are
    Power Steering
    Transmission
    Differential
    Brake Fluid
    Motor Oil
    So overall I've swapped in new steering, suspension, and axles
    Is there anything you can think of that I am missing?
    (Besides Shoving Golf Balls In The Tires....)
    Oh yeah, what is the proper tightness for crown nuts on steering link ends? Mine are pretty damn tight.....
    Anyway, have some pictures
  2. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    damn you....I have to do the same but have no time... /forums/images/graemlins/doah.gif
    looks good, so when will it be wheeling again /forums/images/graemlins/truck.gif
  3. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Re: Finishing Up The Truck - All The Small Little Wrap Up Things - With Pic
    Well if my amazing stint off getting of my lazy ass keeps up, sometime next week
    I need to pull the van gas tank to cut out the cab bottom to drop in part of the new subframe and make better supports for the gas tank, otherwise I could propbably drivie it around tomorrow, that is of course if it doesnt blow up/break/not start/ not shift/leak bad/overheat
    Thank you for the compliment
  4. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    Looks good but your missing one KEY element...
    Other then that its looking good /forums/images/graemlins/thumb.gif
  5. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    You're such a wiener Jeremy
  6. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    Weiner...yes....but with a tailgate /forums/images/graemlins/rotfl.gif /forums/images/graemlins/histerical.gif
  7. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Check It Out, Check It Out, Check It Out, Check It Out, Check It Out
    Ok if you don't feel like reading through the whole top post, here's the stuff I REALLY need to know
    - Is there any wierd process to bleeding power steering?
    - How tight should the crown nuts on the steerinbg links be?
  8. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    You need less lift, bigger tires, and narrower rims. /forums/images/graemlins/shame.gif
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  9. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Hey I always told you it was too tall! /forums/images/graemlins/wink.gif
    I would like some 39.5" IROKS.......
    Hey everbody I'm typing with really greasy hands, I need answers to those last two questions
  10. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    start the motor, take off the cap to the p.s.
    then just cycle the steering slowly a couple of times, also put the cap back on..dont ask /forums/images/graemlins/doah.gif
    oh and dont try to fill while truck is running..unless you want to have a grimy face too...dont ask /forums/images/graemlins/doah.gif
    as for the nuts I would just tighten till its hard to turn, then another 1/2 turn and slide the cotter pins in /forums/images/graemlins/thumb.gif
    I just got mine on the road too /forums/images/graemlins/woot.gif
    new axels, gears, lockers, cross over, motor, wiring, cross over....and more /forums/images/graemlins/peace.gif
  11. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    Off topic-- Nice garage!. Is it a "Miracle Truss" building?.I almost bought one of them,but ended up getting a steelmaster quonset hut garage.Its a good building,but sometimes I wish I had rafters and wall studs,when you want to lift something or make shelves /forums/images/graemlins/thinking.gif.Your truck is coming along nicely too!. /forums/images/graemlins/grin.gif
  12. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Re: Check It Out, Check It Out, Check It Out, Check It Out, Check It Out
    The way I bled my PS system was to jack the front up to where both tires were off the ground, then get in and start the truck. Turn slowly from bumpstop to bumpstop. It will sound nasty, but eventually you work most of the air up. After you can get some power assist when you let it back down, continue to do this until all foaming stops.
  13. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    There are a few ways to do it I'm sure, but how I always done it (and I have done it quite a few times) and am told this is the most proper way to, is NOT start the truck...jack the front with tires off ground, have one person in and turn lock to lock, while other guy fills the reservoire until you don't see bubbles.
    (if you have a cooler and hydro ram, this will take awhile)
    Fluid will move up and down, so make sure you tell the guy to stop when fluid is about to come pouring out...once it's settled...tell him to continue...you may have to buy him a 12 pack or two for his efforts...
    Boss
  14. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Thanks Niel SS75 and Boss for the PS stuff
    Diesel - I have no idea, was built before I was built.... I mena born..... heh heh
    Could be, damn fine building if you ask me!
    Thanks for the compliment
