Finnished my swap
Discussion in 'The Garage' started by big dan, Mar 22, 2006.
  1. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    Just wanted to share my success with everybody. Today I finished my 3/4 ton axle swap and lift. I now have a dana 44 and a 14bff with 4.10 gears. Bye bye 10 bolts with 3.08s. I also put on 4inch lift front springs, thanks to dremu, and got rid of the front blocks from the previous owner. Now I get to order 35s and a membership so I can post pics. Thanks for all of the help you all have given me.
  2. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    Nice,,,,,definitely post pictures, congrats. What wheels you gonna use?
  3. big dan
    Aug 1, 2005
    2,656
    29
    Arkansas
    prolly gonna use the stock wheels that came with the axles. I cant really afford tires and wheels so the stock ones are gonna have to work until i can afford some new ones.
  4. dremu
    Feb 27, 2000
    15,967
    459
    East of San Francisco
    :woot:
    Glad the springs went in ... hadn't heard anything from ya in a while, but I guess it's cuz you were busy :D
    Front blocks :doah: ... I am *so* glad you punted those!
    -- A
  5. IDGMC
    IDGMC 1/2 ton status
    Feb 18, 2000
    150
    Idaho
    I'm getting ready to do the same swap. What headaches did you run into? brake lines swap across? ubolts the right size? I'm about 3 weeks out from doing mine
  6. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    The brake lines from a 10-bolt won't fit a D44. BUT, you can swap out the calipers. 10-bolt calipers will fit on a D44, and vice versa. 1/2 ton, or 3/4 ton doesn't really matter, it's just a year difference. I'm not sure on the exact cutoff, but IIRC 79 and earlier uses a 7/16" banjo bolt to attach the brake line to the caliper, and 80 and later uses a 10mm banjo bolt. Everything else is a direct swap. So no issues with springs, u-bolts, steering, etc.
