Fire extinguisher location???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FWP, Jul 6, 2001.
  1. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Where do you all have yours mounted?
    <A target="_blank" HREF=http://fwp4x4.rockcrawler.com>http://fwp4x4.rockcrawler.com</A>
  2. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Right next to the drivers seat, between the seat and the door, in a snap-in holder, mounted to the floor.............easy to get to with the door open or closed..........hope to never need it!
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<A target="_blank" HREF=http://www.blazzinor.alloffroad.com>http://www.blazzinor.alloffroad.com</A>
  3. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    You can see a where mine is mounted at the link below....
    <A target="_blank" HREF=http://community.webshots.com/user/vwryda>http://community.webshots.com/user/vwryda</A>
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I mounted mine to the left of the the t-case shifter, on the tranny hump with the supplied bracket. I mounted it there so it could be easily reached by the passenger or the driver. I can take a pic if you like.......
    Murphy's Laws on Life:
    "A bird in the hand is worth three Kleenex."
    <A target="_blank" HREF=http://www.K5.rockcrawler.com>http://www.K5.rockcrawler.com</A> *under construction*<P ID="edit"><FONT SIZE=-1>Edited by BlazerGuy on 07/06/01 07:53 PM (server time).</FONT></P>
  5. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Handle Up?
  6. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Does it get in the way of your feet? A pic would be good, if you have time. Thanks.
  7. bigjbear
    Feb 18, 2000
    13,970
    449
    Marietta GA
    Mine is on the R/H side of the trans tunnel. The foot well area is big enough that it doesn't get in the way. I'd snap a quick one but my wife is out with the Dig camera. I can post one next week if you want. Let me know.
    Jim '80 GMC
    Freedom First!
    <A target="_blank" HREF=http://www.bigjbear.coloradok5.com>http://www.bigjbear.coloradok5.com</A>
  8. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Thanks dude, but I'm mounting it it tonight. Got a trail run tomorrow, and I've been putting off installing it.
  9. bigjbear
    Feb 18, 2000
    13,970
    449
    Marietta GA
    Does it have a bracket? If so you can screw the bracket to the tunnel. I ended up getting a better bracket when I did this, the plastic one looked cheep. Try to get one made for a boat or plane. If it is a plastic one I would get some large zip-ties, like the ones they use for handcuffs and zip-tie the bracket to the spare tire mount. That makes it accessable from the back window. I had my old one like that for a while. Have fun.
    Jim '80 GMC & '73 Blazer
    Tread Lightly!
    <A target="_blank" HREF=http://www.gmck5.rockcrawler.com>http://www.gmck5.rockcrawler.com</A>
  10. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Do you still wanna pic?
  11. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I've got 2 - one 2.5 lb Dry Chem mounted on the side panel behind the passenger seat, and another 2.5 lb Halon 1211 mounted on the trans hump in front of the center console.
    <font color=red>Cripplefight!!</font color=red>
    <A target="_blank" HREF=http://pugsley.alloffroad.com>http://pugsley.alloffroad.com</A>
  12. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> On the trans hump right next to the transfer case shifter.
    L8r,
    . Riz . <A target="_blank" HREF=http://www.geocities.com/rizmonkey>http://www.geocities.com/rizmonkey</A>
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Under the driver's seat.
    Tim
  14. 82GMC
    82GMC 1/2 ton status
    May 14, 2000
    553
    Seattle Washington
    Heres what I'd do, As well as keeping one in the cab, Under the drivers seat or somewhere like that where you can grab it easily, I'd take a couple and mount them INSIDE the cab with the hoses going through the fire wall, And aimed at the engine, Reason being the heat if you mounted them inside the engine copartmant itself the heat whould make them explode!! So then in the case of an engine fire you just pull a cord or something and BOOM no more fire, (You hope)
    [​IMG]Inline 6's are cool[​IMG]
  15. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I am going to mount mine on my rollcage. I figured the main hoop would be good. One on each side. I have no top, so they should be easy to get too!
    your right. I don't understand the jeep thing!
  16. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Driver's seat frame, between frame and door. I got a decent-sized one, so with the head of the extinguisher all the way back to the end of the seat frame, the bottom of the bottleextends a few inches into the footwell area. Every now & then I hit it while getting out, and it's not good on the plastic mount. I'm gonna find the metal (boat) mount and replace the mount, and probably throw a Velcro strap on the front part of the seat frame for extra support. Still be quick to get into action, though...
    If at first you don't succeed, failure may be your style...
    [​IMG] <font color=green>Semper Maintenance!<font color=black>
  17. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Thanks Corby, just got it installed. Thanks for offering, not too many folks run out to their vehicle to take pics, measurements, etc- EXCEPT for the guys (and girls) on CK5- awesome[​IMG]
  18. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Kevin, you da man[​IMG] , that's exactly where I thought mine would work the best, and that's where she lives. Thanks to all for the input. You guys are the best............
  19. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Mine has velcro on it... I stuck in on there and it's right under the front edge on my seat (drivers) seat stuck to the carpet.... I opted to not put anymore screws into the floor since the previous owner sort went nuts with them and it's already holey....
    I removed my quote so gay, vegetarian, minority, eco-nazis who love Jesus, nuke spotted owls, vote Gore and smoke medical marijuana won't be offend.
  20. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    Mine is mounted in the bracket hanging from the top right above the console between the seats. Its high enough that I will never bump it, and totally in arms reach.
    Mike
    <font color=blue>Thumper
    85 Fullsize Jimmy
    <font color=red>Lets Go Wheelin! </font color=red>
