Fire Extinguisher mounting in cab (pics & advice)
Discussion in 'The Garage' started by rcamacho, May 17, 2005.
  1. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    I'm mounting a 2.5LB ABC rated fire extinguisher in my truck for emergencies. Any suggestion on where to mount it? I have an interior smittyblt bar and a tuffy console which might be appropriate.
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    center of the steering wheel for easy access:D
  3. rcamacho
    Jul 1, 2004
    1,324
    WA
  4. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Mine is on the floor next to the t-case lever. If you need a picture to envision that, you probably don't know how to work a fire extinguisher. :D
  5. rcamacho
    Jul 1, 2004
    1,324
    WA
    :p:
    Thanks.
    Tough crowd. I'll work on some more entertaining dumb ass questions for the group to work on ;)
  6. JROSS
    JROSS 1/2 ton status
    Oct 12, 2001
    281
    Redding, CA
  7. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    i think this looks really cool and is a very functional spot.
    you may even want to mount one under the hood too... thats where youll most likly need it...
  8. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
  9. dyeager535
    26,979
    Dunno how big the 2.5lb extinguisher is, but I mounted my small extinguisher to the back of my tuffy console, IIRC there are already bolt holes there, I just re-drilled the extinguisher mount.
    I've got the console mounted in the stock location, so I can flip the quick release on the mount easily from the drivers seat. Still get to use the awesome Tuffy cupholders near the shifter too. :)
  10. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    I have a custom seat-mount that houses 2 racing buckets and a B&M floor shifter between them. I have the extinguisher mounted between that shifter and my seat, easily within my reach.
    I don't have a pic of the extinguisher specifically - but here's a side-shot of my interior w/ the custom seat mount.
  11. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Mine is in the same place. Very functional and out of the way. I think mine is like a 7 or 10 lber though. Bigger than the usual ones you see in autos.
    I tried it just sitting to the left of the drivers seat and tucked into the rear compartment but that just didn't seem to work out after my first wheeling trip.
  12. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    for those of you who are getting or currently have a abc fx in your rig, beware of the kidde brand or any other with a plastic head, such as the 10.00 ones. They are ok in some apps but not as much as you would hope.
    the plastic heads do not fare to well in a truck that see's alot of sun, the constant heating and cooling of the o-ring and the head will cause them to fail. Then when you need it most, the $10.00 fire ex just failed and you watch a $5000.00 to $15.000 investment burn to the ground.
    I sell, service, and deal with everything from 2.5 fx's to 20 lbs, to grease supp, to air plane fire carts all day long, I say I see about 5 to 10 of the cheapy 2.5 lbs fx's that are not charged are do to a plastic head or seal that failed.
    your best bet is to get a 2.5 or a 5 lb metal head fx, brands such as ansel are a good name brand.
    also any local guys, I can recharge a fx and recertify it for you for free, I get customers all day long that give me there old ones. :thumb:
  13. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    This is the one I use. About $25.00 at Wally World. I have a smaller one in the wife's K-10 but I'm gonna get two more of the larger ones, one for the '73 and one for the K-10.
    I wouldn't keep one under the hood. You'll get a face full of flames opening the hood if the fire is there.
  14. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    I'll second that, don't bother putting an extinguisher under the hood. And you'd be better off spending your money on air fresheners than those small extinguishers, unless you've had practise using extinguishers you'd be surprised how difficult it can be to use one effectively.
    That goes for home use too. Extinguishers beside the stove might seem to make sense until you have a stove top fire. Extinguishers should be mounted near exits.
    Sorry the firefighter will shut up now.
  15. kotton
    kotton Registered Member
    Sep 1, 2004
    64
    Orange County, California
    I mounted one in the back by the spare tire, now that I read all these I feel like an idiot :blush:
    just thought Id share that , Im gona pick another up and mount it by the t-case shifter that sounds like a good idea.
  16. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    Don't feel like an idiot, feel lucky, because the only way to know what to do in the case of a fire is to have one, or have someone teach you. Luckily it was the latter!
  17. dyeager535
    26,979
    So for vehicle fires, can you post some tips, etc?
    I can already tell the small extinguisher I carry is going to be inadequate, I guess something is better than nothing, but is there a size that is still portable/mountable in our rigs that might do the trick, or at least give us a fighting chance?
    I personally have no idea the best thing to do if you've got an underhood fire and a smaller extinguisher. Even if it's not your vehicle on fire, you might be able to help someone out whose vehicle IS on fire. Just makes sense to know the best approach.
  18. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    good point dontoe and chances are you will burn the hell out of your hands trying to open the hood.
    I like the idea of having the extinguisher next to the seat like yours where it is easy to grab when needed.
    Don't forget that extinguishers need to be serviced every year also.
    Now this firefighter will shut up!!! :D
  19. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I've used a couple of those cheap ones you buy at Wal-mart. They work alright. Nothing to write home about. Definitely not as nice as the kinds you find at an industrial place where they run fork lifts. The trick seems to be to remember to smack them against a tire before you use them. That and remember you have a finite supply of retardent coming out of that extinguisher.
    I carry two of those little ones behind the seat in my rigs. One on each side. Chances are if you need more than just one of those extinguishers either your aim sucks or you did something stupid. As long as there isn't something fueling the fire (like gasoline being pumped out because you were stupid and ran the fuel pump off the ignition switch) then one of those little extinguishers seem to work alright for an underhood fire. If you let the fire go and it has an opportunity to start burning plastic (like the dash or the AC box under the hood) then you'd need a monster fire extinguisher to put it out.
    In the house I have several large fire extinguishers. Usually right where you see them all the time. I've got one at eye level in the front porch. In the barn I have a 20lb one.
  20. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Every three to six months, take a rubber mallet, pound up and down the side, and shake the extinguisher.
