Fire fighters or those who know about fire extinguishers
Discussion in 'The Garage' started by cybrfire, Apr 13, 2004.
  1. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    I have access to a whole pile of empty fire extinguishers. Are they usable for any kind of quick air tank? Co2 and so on. Does anybody know what kind of pressure they can handle? They are like the fire extinguishers that hang on a wall. Not as heavy as the SCBA tanks.
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    they can hold pressure. they are suposed to be hydrostatically tested every so many years. that is the ones that are refillable. some are made to be thrown away after 1 use.
    really it depends on which ext. u got as to weather u can use it as a co2 tank.
    sorry for the vague answer,
  3. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    any tips on which ones to look for. Most of these are yellow in color. I don't know if that matters or not.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'd get all of them.
  5. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Heck i have a couple here, i was wondering, i have heard they can be refilled if i take them to the fire station??
    Any body ever heard of this deal?
  6. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    I've heard of that as well. I bet though if they figure out that you are filling your tires with the C02 they won't fill them for very long. Can't say as I blame them. Around here the local paint ball type folks could fill them for me.
  7. 4xcrazy
    Oct 31, 2003
    9,472
    5
    Well i wasn't really referring to using them for that purpose, /forums/images/graemlins/doah.gif i'd kinda like to have one in my truck. /forums/images/graemlins/waytogo.gif
  8. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i work for the memphis fire dept. i know we will not refill them. it is a huge liability deal if we fill it u get hurt cause it does not work right & we get sued. there are also many styles so it would be hard to have everything on hand to re-fill all types. the type we have on our pumper uses a seperate canister that screws on the side to hold the propellant for the ext.
    if it is refillable it should have a plate on it that tells the specs on how much dry powder & pressure to fill it to.
    also the heavier the tank is the better it would work for what u want.
  9. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    The only kind you can refill with the kind of pressure you need for an air tank are the heavy CO2 extinguishers. Dont put much pressure in the dry chemical kind. They can rupture and may injure you bad. Dry chemical extingushers operate on low pressures. If I rember right they are pressure tested to 350 PSI. A normal charge for a 5 pound dry chem is 190 psi of nitrogen.
    You can have them refilled by any fire extinguisher service company.
  10. biobry
    biobry Registered Member
    Dec 26, 2003
    76
    North Florida
    It seems to me that these would make a great onboard air supply for trail use...could hold enough air to pump a few tires back up after rock crawlin' without having to install the onboard compressor...
    Bryan /forums/images/graemlins/k5.gif
  11. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Seems to me that a cheap 5 gallon portable air tank sold at your local walmart would be cheaper and safer /forums/images/graemlins/thumb.gif
    You can pick one up for $25-30 new (maybe $5-15 used) and refill them for free at most gas stations.
  12. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    Last time I got mine at wally world they were 7 gallon tanks for 16$ thats what I used for my onboard air tank.
  13. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Got any pics of where you mounted your tank?
  14. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    Problem with them is they aren't going to fill your tires even once probably, unless it is hooked to an onboard compressor. That's why I was interested in C02 and the fire extinguishers capability to hold pressure. C02 stored in a liquid expands many times giving you the ability to deflate and inflate your tires "x" amount of times before refills.
  15. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    have you looked at your local pop or beer distributors? i am not sure what the inital cost is, but it costs 15 bucks for a refill, i dont know how they measure tanks but it is ~32 tall and 8" diameter.
  16. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    If it's a CO2 extinguisher go for it. Otherwise look for another type of tank. I'd try one a home first to make sure the flow rate & pressure will work for a tire.
