fired finally
Discussion in '1982-Present GM Diesel' started by mike race, Jan 14, 2002.
  1. mike race
    mike race 1/2 ton status
    115
    Orlando, Fl
    FINALLY. I still have one problem I haven't figures out yet. I have a major fuel leak only when running. It is coming from below the seconday filter. I think it is one of the return lines? Can't visibly see anything without ripping almost the whole top end off. Any suggestions.
    Mike
    fix'n finally
  2. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    The return lines jump from one injector to the next, shouldn't be that hard to see with-out ripping parts off. At the end cylinders, towards the firewall, there should be a cap on one side of the return line nipple on the injector. 'Clear as mud?
    Real trucks don't have spark plugs!
  3. 6.2 man
    6.2 man 1/2 ton status Premium Member
    636
    Curtis , WA
    There is also a return line of the injector pump that goes under the air manifold ....might be leaking there too ???
