Firewall and Distributor clearance
Discussion in 'The Garage' started by bnate, Apr 23, 2006.
  1. bnate
    bnate 1/2 ton status
    Mar 6, 2004
    138
    San Jose, CA
    Have a SBC/SM465/205 in a 73 Blazer with a dropped transfer case. Need to leave it dropped for the driveline angles. The HEI distributor is rubbing against the firewall; I tried to pound alittle space into the firewall....also tried to loosen/remove mounts/crossmembers and shimmy forward toward radiator w/out much success.
    ....I have *searched on this topic*.
    Would going to a non-HEI distributor be worth it if it only produced a few inches of space?
    ....what would the diameter of the non-HEI be?
    Is there another way that distributor caps latch other than the screw latch to the bottom?
    Thanks in advance.
  2. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    I would either put a points type distributer in with an electronic ignition conversion from either pertronics or crane in it, or just go with an aftermarket msd (or other manufacterers) distributer thats already electronic.
  3. diesel4me
    Jul 24, 2003
    17,579
    945
    Massachussetts
    two options..
    The point style dizzy is about 1-1/2" smaller in diameter..a step backwards as far as performance though..less spark voltage,and points cost over 20 bucks now,few parts stores even keep them in stock here anymore..since its been 30 years since points were used,they consider them "antique",and are priced accordingly now....
    If you use an aftermarket one,be sure it has a vacuum advance..you dont want a "race only" centrifical advance only distributor..
    You may find a stock GM HEI used in later Camaros have a smaller cap,but I'm not sure if the had vacuum advance or not..I'm thinking not,the module and computer eliminated vacuum advance,I'm 90% sure....
    You could massage the firewall with a bigger hammer,or cut out a "window" and box it in from the inside...and run the HEI you already have...:crazy:
  4. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    MSD has a Ready To Run magnetic distributor which has a nice small cap. That is what I run on my 69 K20.
  5. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    the point issue is the whole reason I said "with a conversion kit in it". The conversion kit turns the points type distributer into an electronic ignition system while still getting the benifits of the small distributer with vacume and mechanical advance. Its about the only deal that has no major issues or setbacks and only cost 64.00 plus the distributer. I see distributors on ebay and salvage yards for 10-20 all day long.
  6. bnate
    Mar 6, 2004
    138
    San Jose, CA
    Thanks everyone for the ideas. Will attempt after blowing up 2 sets of cap/rotors.
    Regards. :laugh:
  7. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    How about new poly body mounts either stock or a real short body lift? This would give you a little lift off the distributor. The poly's will be a little stiffer and may help with the body shift.
    My rubber mounts are pretty much crushed on my 79.
