firing order questions...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ben, Mar 25, 2004.
  1. Ben
    Ben Registered Member
    May 3, 2002
    96
    Pick a country in SE ASIA!
    On my manifold, SBC, stamped into it is the firing order; 1,8.....
    Is this related to the distributor cap order of the plug wires?
    Number 1 wire does not have number 8 wire next to it on the cap. No problem?
    What is the firing order stamped for?
    Thanks!
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yea the wires on the cap should go like this
    .5 7
    6...2____ plugins
    3...1
    .4 8
    if they dont then the motor would not run right
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    I would rotate that cap you drew there one notch clockwise really, i have always seen 1 and 8 facing the front, with one facing the no.1 piston. /forums/images/graemlins/thumb.gif
  4. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    That is correct. The number one wire on the dist. needs to be facing the number one cylinder, or at least half way between the 1 & 3 cylinders.
    -Harrison
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Actually, guys, I'm pretty sure that as long as the wires follow the proper firing order you can start with the #1 wire on any post on the dist. cap.
    Am I wrong? /forums/images/graemlins/dunno.gif
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You are correct.
    You can make number one anywhere you want on the cap as long as the distributor is timed to however you set it up.
    I always do it as it is above in the picture so that it's like factory. That way I never have to remember how it is the next time I work on it.
    Where the number one plug wire hooks up makes no difference...when you set your timing it's gonna move around a bit anyway.
    So, you're correct. Number 1 can be anywhere, as long as the wires are in the correct order clockwise from there, and you time it accordingly.
  7. 4xcrazy
    Oct 31, 2003
    9,471
    5
    Well they need to be close, we tried that on a buddy's truck, and couldn't get it to fire until we got them close, but i understand what you are saying. /forums/images/graemlins/waytogo.gif
    But why not just have look "right" while your at it, ya know? /forums/images/graemlins/rotfl.gif
  8. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    You can also royally [darn] yourself over...ask me how I know /forums/images/graemlins/doah.gif
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yep you can do that too. /forums/images/graemlins/rotfl.gif
  10. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    one thing ive noticed, when you go to buy wires and get vehicle specific, they dont fit unless you have #1 where the factory put it. Trust me, i found out the hard way.
