First Gen Pullys
Discussion in 'Parts & Trucks Wanted' started by arq, May 23, 2004.
  1. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    I'm looking for a set of first gen pullies to use with or without A/C. I need the one that mounts to the water pump and the one that bolts up to the harmonic balancer.
    ARQ.
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    big blk or small block?
    if small blk i am guessing it would be for a short water pump?
  3. ljbear
    ljbear Registered Member
    Mar 24, 2004
    92
    Grass Valley, CA
    I think I may have them, I'll check and get back to you.
  4. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    i knew i forgot something. i'm looking to put them on a small block chevy 350, short style water pump /forums/images/graemlins/smile.gif
    ARQ.
  5. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i am pretty sure i have them but i will have to dig for them i will look when i get home.
  6. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    cool, send me a PM. i almost forgot about this post.
    ARQ.
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    you know i just scrapped several crates full of 72 and 68 older pullies and bracketries and such, humm..
    ill see if i got anything at all that i missed when i scrapped out though,.
    you needing the flat or dished crank pulley and what diameter and depth for water pump and what bolt pattern on the pump one, small or large ? large was mainly long pump pattern and small was mainly small pump pattern but not all years.
  8. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    I know i need the flat or dished crank pulley. not sure about the water pump one. I'll check and let you know.
    ARQ.
