First Generation engine crossmember
Discussion in 'Vendor Forum' started by cybrfire, Jan 3, 2007.
  1. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    First generation engine crossmembers!
    These will hit the website for $165.00.
    Channel brackets go inside the frame rails giving you a nice flat platform for the engine crossmember. 4 Bolts on each side plus the engine bolts (9/16") and the crossmember is out. Then you'll have easy access to the oil pan should you ever need it.
    Everything you need to do the swap is included except the paint!
  2. '71k204x4454
    '71k204x4454 Registered Member
    Dec 28, 2004
    60
    Hood River Or
    Do you know how it fits with a big block and what about crossover steering? Looks good just like all your stuff by the way!!!
  3. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    Nice work as always Kert!
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    Kert.... stop with the trick ass parts will ya? i need another truck that all of your goodies fit on now. :deal:
  5. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I need one!!!
    how much room do they allow compaired to the stock as far as oil pan clearence. my moroso pan maybe deeper then stock.
  6. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    DAMN!! Nice :bow: :bow: !
    Any pics of it bolted up with and without motor :D !
    Use existing bolt holes?
  7. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Will that work for a 2wd truck? Does the bottom of that crossmember set up any higher in the frame than the stock one? My buddy is dropping a 71 truck and is looking for a new crossmember that doesn't hang down so low.
    Let me know quick and you can probably send it with my other order.
  8. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    OK, try to answer everybody here.
    2wd, i doubt it. I didn't try it in a 2wd frame so can't say for sure either way.
    It tucks up pretty close to the oil pan. so they may allow more room underneath. I don't have specific dimensions. We tucked it in as close as we could. With an aftermarket pan there may be clearance problems. There is approx. 1/4" of clearance on the corners of the pan. That is where it is tightest. Shouldn't be difficult to notch the tube and plate it back in.
    No pics without the motor sitting on it. It does use existing holes. No drilling of anything is required, however, these frames do vary a bit so it is possible a hole may need to be reamed a smidge. We run the holes out fairly snug. I don't like the idea of doing all the holes big and sloppy to accomodate things like this when it very well may be only one hole causing problems. RGV72blazer said his fit perfect.
    Big blocks should fit the same. I have heard reports of different shaped pans on big blocks. I don't have all of them if they exist to test them though.
  9. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    man now I really need one, payday is tomorrow so your phone will be ringing.
  10. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    no, it wont. it lacks the UCA and LCA mounts. basically, it would probably fit in the frame, but you wouldnt have any place to mount the suspension then. :deal:
    this might help your buddy however....
    http://www.captkaoscustoms.com/chopcross.html
  11. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    do you make these for 2nd gen trucks as well? I couldn't find it on your website if you do.
  12. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    Very soon!
  13. thedrip
    Dec 13, 2003
    1,129
    Chattanooga, TN
    I want to order one this week. that soon? =)
  14. chevyin
    chevyin 1/2 ton status
    Sep 14, 2005
    1,324
    Pismo Bch CA
    Engine Crossmember
    Kert:
    Received the crossmember kit and it looks good and seems to fit fine. The reason for this post is that I am using the crossmember to mount a 396 BBC into my 72 Blazer. To do this I have to move the motor forward in the frame. Doing this means that I have to drill new holes for mounting , or weld the frame inserts to the frame. I don't like to weld components to the frame for obvious reasons.
    After receiving the crossmember and temporarily installing in the frame I can see that drilling holes in the frame that align with the predrilled holes in the frame inserts will be a very difficult task. In the instance where the crossmember is to be moved, I think that the inserts should be made without the frame mounting holes. Doing this will allow drilling the frame and insert from the top and bottom. Please let me know if you could make me a new set of inserts without the holes.
    I am in no hurry, so you can do it the next time you make a batch of crossmembers. I can send back the inserts I have, or will buy a new set.
    I can use the predrilled set, but would have to move the bolts toward the center of the inserts. Probably just being picky, but don't want to risk this high torque motor breaking mount bolts.
  15. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    I'll make ya a new set no prob. Send yours back and I'll get a set coming to you! If it makes life easier then shatfire, why not!
    Kert
  16. chevyin
    Sep 14, 2005
    1,324
    Pismo Bch CA
    Thanks, I have the engine setting in the frame right now for fitup of engine and transfer case. As soon as I pull the engine back out I will send to you. Like I said, this is a major project so I'm in no big hurry.
    Just to be clear, everything fits fine, I just need the inserts that go into the frame.
    John
  17. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    Yep, I got ya. Big block, 2" forward. No frame holes in the boxes to facilitate drilling the frame and boxes simultaneously. Guaranteed bolt alignment.
  18. chevyin
    Sep 14, 2005
    1,324
    Pismo Bch CA
    Kert:
    If you want to see some pics of the crossmember fitted to a big block, go to first gen forum "some progress pics".
  19. thedrip
    Dec 13, 2003
    1,129
    Chattanooga, TN
    Still waiting on an annoucement of the 2nd gen crossmember! I should take video of the frame flex I have with the engine crossmember and trans crossmember out. I can ramp 8-10" with just the chassis.
  20. RGV72BLAZER
    RGV72BLAZER 1/2 ton status
    Jan 23, 2006
    2,425
    Edinburg*San Bene*Online-The Real South Texas
    hey Kert, had some trouble getting the darn thing into my Gen1. let me rephrase, it was a PITA. lol. my buddy broke one of the bolts in the block when he was tightening it, so we're going to put some tack welds in it, you see any problem with this or should i pull the motor out again and fix the broking bolt? also there's very little clearance under the oil pan and on one part is even making contact, may be a crooked pan but doubt it. any thoughts?? thanks.
