First Intake Manifold or Carb?
Discussion in 'The Garage' started by prossett, Oct 12, 2005.
  1. prossett
    prossett 1/2 ton status
    Sep 29, 2005
    165
    United Arab Emirates
    Given budgetary realities, at Summit Racing I can either get:
    Edelbrock EDL-71012 Intake Manifold, Performer RPM, Dual Plane, Aluminum, Permastar, Square Bore, Chevy, Small Block, Each $239.95
    or
    Edelbrock EDL-9973 Carburetor, Remanufactured Q-Jet, 795 cfm, 4-Barrel, Spread Bore, Hot Air Choke, Single Inlet, Each $375.95
    Which one first?
    '83 Jimmy, 305 stock engine, manual gears, above order will include headers and full exhaust.
    If I can get these parts cheaper maybe I can squeeze in both - any suggestions where? They must ship overseas and take VISA.
  2. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
  3. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    I don't think I would put a 795 cfm on a 305. I have a 600 cfm performer carb on a 283 and I love it. its just about right..
  4. Ben B.
    Ben B. 1/2 ton status
    Sep 1, 2005
    352
    Central PA
    Holy sh*t...you don't want a 795 cfm carb on a stock 305. :doah:
  5. prossett
    Sep 29, 2005
    165
    Bit excessive, eh? I've got lots to learn...
    Here's what the stock carb looks like, can you guys ID it?
    So far I've managed to ID the transfer case, gears and axles, but still not the engine - the VIN says it's a 305.
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Thats a Q-jet , of which the lowest one was still 750 cfm , early 80's NON-COMPUTER with electric choke . The casting numbers will tell you more than that .
    And they run great on 305's considering the primaries are tiny , and the secondaries only open as needed based on airflow :D
  7. SHAWNSTER
    SHAWNSTER 1/2 ton status
    Sep 24, 2002
    211
    DALLAS,TX
    palm tree island-off topic
    off topic but have you seen or heard of that island thats shaped like a palm tree and was made of sand-the prince of Dubai had it built-i just watched it on tv last night-every property has a ocean front view
  8. prossett
    Sep 29, 2005
    165
    OK! ID'd another part - Quadrajet carb. Thanks.
    All I know is I just bought this beautiful K5 and I'm loving every moment; even if my Haynes repair manual is taking forever to get here!
    Changed all fluids, oiled and greased her, couple of things that need replacing (minor) and then all I have to do is figure out how to get her to climb sand dunes!!
    Back to topic, so if the stock carb is already equivalent cfm to the Summit Racing one, why bother changing or rebuilding it?
    And same story with the headers...
    I've run mostly Wrangler, and increasing air in and out is key to better acceleration and longer climbs. What mods would I need for my Jimmy?
    And for the http://www.cnc-motorsports.com/category.asp?CtgID=7753 guy - thanks buddy!!! I like those prices a lot more than Summit!!! You just saved me $$$...
    And for the off-topic guy - yeah, 2 palm islands being built as we type. Each one so big it will be noticeable from space... why? The weather sucks down here 6 months of the year, but the other 6 it's just perfect: winter!
  9. RootBreaker
    Nov 29, 2001
    5,117
    173
  10. prossett
    Sep 29, 2005
    165
    :D
    Does anyone know if the stock Quadrajet carb shown in the pic above is square bore or spread bore?
    And how would it like to sit on top of an air intake manifold instead of right on the engine?
  11. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Spread Bore for Q-jets , Carter Thermoquads , Holley 4165's , and a few others .
    Square bore for most Edelbrock/Carter afb's avs's , Most Holley 4150/4160 , and several others :D
  12. monster man
    monster man 1/2 ton status
    Oct 20, 2003
    282
    Reno, NV
    I'd definitely do the intake over the carb first. in fact, I doubt I would even upgrade to a different carb. If that one gives you trouble, rebuild it.
    I disagree that headers and intake are worthless without cam work- Swapping to a dual plane aluminum manifold not only saves about 40 pounds of weight, but in combo with the headers I was able to light my tires up without using the brake or neutral drops. It makes a big difference, AND my mileage went up at least 1 MPG afterwards. Do it.
    In the tight confines of a newer truck with more underhood equipment spark plugs might be a problem, but I can access every plug without a glitch on my '73 truck. I'll never go back to manifolds.
  13. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    why not? the factory did. a QJet wont feed an engine more air/fuel than it needs, you cannot overcarb with a QJet.
  14. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    you're forgetting the improved cylinder scavenging you get with headers. headers are a great addition to a mild engine. the more air you can get it, and the more air you can get out, the more power you will make.
