first issue with new GM intake for TBI
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by solowookie, Sep 21, 2001.
  1. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    ok guys... it seems as if when I bolt down the distributor it still doesn't go down far enough to hold it in place...
    I should have known better because it did not come close to holding the priming tool in place, but I 'assumed' that the distributor wouldn't have that problem... however, the thing keeps working its self outta time.
    well it does have that problems, and I'm gonna have to fab something up that will hold it in place. I'm gonna try to get one out of a just yard that will hopefully game me something I can mess up without having to do it on the only one I got...
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>link to k5's</a>
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Bump the motor over, it'll fall the rest of the way in.
    Tim
  3. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    it is all the way in... that is not the problem.
    in comparing intakes the distributor sinks a lot lower then it does on the stock one. the small metal peice that hold the distributor in place, and from turning back &amp; forth, is unable to go down far enough to hold the distributor solid.
    I think what I am going to do is to take a large washer, cut it in half, and then jb weld it to the bottum of that peice. then when I bolt that down it will keep the distributor from turning. then when I time this thing I can lock down that distributor so it will stay put.
  4. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    What are you looking for from a junk yard? I have a stock 350 TBI intake sitting in my garage as a spare if you want to buy it off me cheap!!
    Ratch
    <a target="_blank" href=http://k5.8m.com>k5.8m.com</a>
    **Ever stop to think... Then forget to start again?**
  5. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    stock intake won't bolt up to vortec heads... I'm just looking for a spare peice holds the dist. down &amp; in place... that way if I get to creative (known to happen) fixing this one I will have something to fall back on.
  6. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    Pics please, my engine is going in w/ that intake, engine guy hasn't mentioned anything about it though, he said for me to call him on Monday. Thanks!
    Dawson
    Raleigh, NC
    88 K5, 6" lift, 36" TSL Radials, 14 Bolt, Rancho 9012s
  7. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Oh, sorry, didn't know you had Vortec heads! It's been a while since I've hung out on this board...
    Ratch
  8. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    actually it really isn't that big of a deal to fix, and you just gotta be aware of it.
    I will post pics when I'm done though. I'm really happy when the way this thing runs, but I'm really disappointed when it isn't timed right. oh, and I only gotta about 100 more miles until this thing is broke in! (which will probably happen today!)
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I don't want to mis-lead you, so I would just like to ask, can you give me some more info? What is the problem? The intake is too short, so the base of the distributor isn't touching it? Was the block decked?
    Tim
  10. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    this doesn't really have to do with how the distributor fits, the distributor fits nice... but, the part where you bolt the peice that holds the distributor down is higher then the stock one.
    so what happens is the distributor is correct, but you got a little metal thing with a bolt that holds the distributor down. when you want to turn the distributor you loosen it, and turn it. then when you are done you tighten it back down so it wont' get out of timing.
    well the problem is this, when I try to bolt the distributor down it doesn't hold it down solidly enough. when it is bolted down tight the distributor is still very easy to turn, but not as easily as if it were not bolted down at all.
    does any of this make any sense???
  11. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    MAkes since to me. But it is hard to picture what it is that your talking about making. But Im with ya.
    "you know... the guy with the BAD A$$ spring perches!!![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  12. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    when I get the peices out to modify them I will take pictures of this stuff so you guys can get a better picture of what I'm talking about...
    should be pretty easy to fix, but my back went out on me today (I got 5 hurniated disks)... It will probably monday when I get this finished up.
  13. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Jeff, are there two 90 degree tabs on the hold-down? Could it be upside down? I think I remember someone I know having something like this and that being the problem.
    If it is in right, could you bend the tabs down more?
    Ratch
  14. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    actually that is already my latest thought on this; instead of putting something on the bottum I'm going to put it in a vice so I can bend it a bit more.
    I don't think it is going to take a whole lot. with this being my first engine rebuild I didn't realize how tight that should have been. in hind site I should have been more thorough in adjusting that when it was much easier to get to.
    just one of the many things I have learned from my first engine rebuild.
  15. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    If I'm understanding right you could grind (the dist hold down)a bit of the area that bolts to the intake so it would sit lower and hold down the distributor.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  16. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    oh yea I could, but if you think I'm gonna either a) take out the intake to do it, or b) do that with my record of fires [​IMG] you are crazy... LOL
    I definately think my easiest recourse is to bend that peice a bit. if I screw it up I'll get one off a junked vehicle somewhere.
  17. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Jeff,
    Are you useing the hold-down that is made out of flat steel with a little offset in the end of it? I think the hold-down that you need if the one made out of steel wire that is bent 90 degrees on the end. There are the two different types and my guess would be the you are using the wrong one.
    '85 K5 : Run it til it breaks, then fix it and go again!
  18. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    oh the hold down I am using definately is not made out of wire, or bent 90 degrees on the end.
    guess that answered a lot... maybe that stupid thing was off that 77-78 305 also???
  19. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    I see you got a fun back there too solowookie. I've got a cyst growing inside my spinal column thats pushing on a nerve and causing a disc to hang over. Does strange crap to my left leg cause of that nerve. Doesn't it suck trying to tinker on the truck and you can't bend over some days.
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  20. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    you know it is kinda funny because I could have not more of done an engine rebuild with my back for the last 2 1/2 years then I could have lifted a truck.
    I went ahead and started on the rebuild, and as soon as it was over my back went out on me... so I guess while I'm sitting here thinking I had a ton of bad stuff happen during that rebuild I need to remember I actually completely it without any major incidents, and I was blessed enough to do it.
