First magazine article i've seen in a few years....
Discussion in 'The Garage' started by laketex, Apr 6, 2004.
  1. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    First magazine article i\'ve seen in a few years....
    ....that made me want to buy the mag.
    The mag was 4wor
    The article was about mounting a winch btwn the frame rails and under the radiator on a K30...exactly what I want to do with my K5. Might be tighter, but I bought the mag anyways..
    Anyway, just wanted to share.
  2. tRustyK5
    Jul 23, 2000
    36,184
    1,388
    E-town baby!
    Re: First magazine article i\'ve seen in a few years....
    I bought the same mag for the same article.../forums/images/graemlins/waytogo.gif
    Which envelope did the money for your new magazine come from? /forums/images/graemlins/grin.gif
    Rene
  3. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Seems I did the same here to be able to save space and departure angle!
    Bill
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    I've got every issue of 4WOR since May '85. /forums/images/graemlins/whistling.gif /forums/images/graemlins/histerical.gif
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    4WOR is the only mag I subscribe to anymore... hint hint
  6. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif
  7. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Can someone scan it and send it to me?
  8. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Me too me too! They don't have the new one yet where I usualy get mine /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif
  9. laketex
    6,220
    North Texas
    SLUSH....dont tell Michelle. /forums/images/graemlins/blush.gif
    and I would scan it but i'm scannerless....sorry. /forums/images/graemlins/frown.gif
  10. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    they did it wrong anyway
    why do they mount it with the bolts vertical rather then against the bulkhead?
    do Warns not work mounted that way?
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Are you implying that the bolts are stronger in tension than shear?
  12. laketex
    6,220
    North Texas
    /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
  13. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    the bolts should only stop the winch from falling on the ground
    the load tension should be pulling the mounts into the bulkhead
    I cant find a picture that shows the bolts on mine, the welding flash I took isnt helping
    I have a 1/2 plate welded across the back of the frame rails
    it is drilled for the mount and opened up for the fairlead
    the bolts are not involved in the work
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Ahh. So build the crossmember in front of the winch, bolt the winch to it, and when the cable pulls, it will pull the winch forward into said crossmember.
    Like this:
    -Winch/bolts-
    ------------- Crossmember
    ===================== front bumper
    As opposed to
    -----------Crossmember
    -Winch-
    =================Front bumper
    I understand now /forums/images/graemlins/rotfl.gif
  15. laketex
    6,220
    North Texas
    What? Youve got to be off your rocker. You want the winch to move into a crossmember while you're pulling?
    I want my winch to be hard mounted...If there's a safety catch in there in case the bolts break, then ok...but I don't really see that as nessessary. And 1/2" plate? Why? The frame rails are much much thinner and would bend first....I'd personally rather bend my plate. I'd think that 5/16" or at the extreme end, 3/8" with a formed bend to make it like a channel would be plenty!
