first mod
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by coolhandluke, Nov 2, 2001.
  1. coolhandluke
    coolhandluke 1/2 ton status
    Oct 23, 2001
    116
    Dallas Texas
    what was the first mod you did when you got your K5, what is the first thing you would recommend someone do if they get a pretty much stock blazer?
    sometimes nothing is a real cool hand
    what we have here is a failure to communicate
  2. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Ditch the auto locking hubs!!!!! If you have them that is.
    '85 K5 : Run it til it breaks, then fix it and go again!
  3. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    The first few months I had my Jimmy all I did was fix stuff. I put headers and dual 3 chamber flowmasters on to relace the bad exhaust, replaced my rear springs because one was bent, new guts in the tailgate and a major tune-up that wasn't finished until I had swapped a better cam into it.[​IMG] My truck was already lifted 4" and on 33's when I got it though.
    My first real mod was getting rid of my 2.73 gears and half ton axles. I found a deal in the local paper for a 14 bolt FF, D44 with 3.73's plus a SM 465/NP205 and both driveshafts for cheap.
    I'd concentrate on making it reliable first. If it already is then take it out and do some mild wheeling in stock form. You'll get a much better idea of what you'd like to do to your truck to make it work better after you've wheeled it a bit. Lockers, lift, and bigger tires are the big three for off-road performance.
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  4. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Check your frame for cracks.My first mod was a weld in frame repair kit and welding up all the other cracks in the frame.
    A balanced diet is a beer in both hands.<a target="_blank" href=http://community.webshots.com/user/beaterwhang>community.webshots.com/user/beaterwhang</a>
  5. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    A fellow 83er. Welcome to the best site on the web. My first mod was replaceing the stock stering wheel with a GT wheel and anti-theft system. It was not cheep. 2hun bones. But it works. The next mod was to take off the AIR DAM, it gets in the way of aproch and departcher(sp?) angels. But like TRustyK5 said make sure its reliable. Be sure to change all of fluids (tcase, diffs, trans)
    Have fun and remember it dosen't happen over night.
    Late KEN
    P.s. Save the old auto hubs, you never know when you may need to swap.
    DANGIT it's not a bronco!
    <a target="_blank" href=http://community.webshots.com/user/kensk5>My Picts</a>
  6. coolhandluke
    Oct 23, 2001
    116
    Dallas Texas
    ok, first, what's wrong with the auto locking hubs, are they just weak?
    How much do manual hubs cost, and how hard are they to put in?
    How do you find out your stock gear ratios?
  7. fright89
    fright89 1/2 ton status
    Sep 27, 2001
    279
    boston
    shock mounts and shocks. mounts were cracked. look for cracks in the frame. also took fuel pump out of tank.
  8. schwinnd
    schwinnd 1/2 ton status
    Feb 26, 2001
    109
    SE Washington
    Let's see new radiator, alternator, starter, battery, had a blown head gasket/new gaskets, edelbroke manifold, crappy worn out tilt steering, new non-tilt from junkyard, new rear axel's (after one broke last wednesday) new brakes all around. Just trying to make reliable so I can start modifying it.[​IMG]
    Just collecting rusty mid-70's chevy's
    1976 Blazer, 1975 Vega SW
  9. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    Shop around, I picked up my Warn Manual HUBS for $70 I think on sale at 4Wheel parts. It is a simple job just need grease and a few screwdrivers and allen wrenches. You do not need a conversion kit if they try to sell you one. You do have a 10 bold front axel?
    I did the swap in about an hour. due to cleaning out old grease and repacking with new. GOOD LUCK
    KEN
  10. Mr.Chevy4x4
    Jun 16, 2000
    1,932
    Sims, NC
    Yes, the auto hubs are weak and unreliable. They are very easy and cheap to replace, should be able to do it in your driveway in under an hour.
  11. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    The auto hubs are kinda weak. Most people here that have/had them have had problems with them. Manual hubs are not that expensive and it's supposed to be an easy swap.
    You might check the inside of the glovebox for the build codes for your truck. There will be a ratio code. The problem is if the diff's have ever been swapped, or a ratio already changed that info won't be accurate. I'd recomend pulling the covers off the diff's and getting the numbers directly of the ring and pinion. It's a great time to change the oil in the diff's anyways, especially if the truck is new to you.
    Rene
  12. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Automatic hubs are weak, but also not necessarily the best for us just because how they operate. Plus, you don't really know if they are locking correctly. Manual hubs are inexepnsive and easy to replace. Took me about 10 minutes per side, but I know those hubs like the back of my hand. Do a search on this site and you will find some detailed info about manual hubs. Nice thing about manuals is the you know when your hub is locked.
    First mods I did were new bumpers. But that's because my bumpers were damaged in an acident. Next was a high amp alternator, but, that's because my factory one was going out. My first mod for fun (not a repair), was a 4" suspension lift. Well, my rear springs were sagging and had to be replaced, so I guess that was a repair, too!
    Have fun and plan out the major stuff you want to do before starting. It sucks to pay $1000 to put lockers and new gears into an axle and then replace the axle 6 months later!
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  13. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I got 2 like new Warn premium hubs off of a 10 bolt and a long side axle shaft for my D44 for 40$ at a jurd here.
  14. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    First thing I did was ditch the factory exhaust.
    89 K5 Silverado, 4", 33's, 3/4 ton axles
    <a target="_blank" href=http://mudfrog.rockcrawler.com>http://mudfrog.rockcrawler.com</a>
  15. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    First thing I did was put on a 4" lift and 35" tires. Twisted the rear drive shaft and upgraded to a one ton. Blew up the rear diff. Replaced it with better gears. Destroyed the front axle. Put a dana 70 in the rear. Currently rebuilding a dana 60 to replace the front axle.
    A computer once beat me at chess, but it was no match for me at kick boxing.
    <a target="_blank" href=http://photos.yahoo.com/dana60manual>http://photos.yahoo.com/dana60manual</a>
  16. HispanicPanic
    HispanicPanic 1/2 ton status
    Mar 21, 2001
    351
    El Paso, Texas
    the first thing i can honestly remember spending a big sum of money on was a system for my Jimmy ( i mean i am Hispanic and you know we cant just listen to the stereo we need to bump the stereo [​IMG]) Now that i remember how stupid i was i wouldnt spend that much on a system again the first thing you should do is check saftey first frame cracked, steering box, tie rod ends, ect. one its all good spend your money on a lift and go from there $$$$$$$$$$$ and when you think your all done $$$$$$$$$$$ and again$$$$$$$$$ trust me it never ends
    <font color=purple>I put the Panic in Hispanic</font color=purple>[​IMG]
    <a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
  17. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Firs thting i did. KN filter... second thing, 4.56 gears, thats all i have now. Next i have to fix my window then im getting some flows... or a ORD steering box brace
    6in 87' K5 w/ 35" BFG muds.
    305/Sm465/ NP208
    Kn, 4.56's.
    next...highflow cat, single inlet dual outlet flowmaster with 4" tips =D
  18. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    First thing is base your mods on what you're going to do. Alot of these guys wheel alot and are gonna recommend some bitchin off-road stuff. You might be a pavement pounder like me and not need all of it. I've 3/4 ton springs that gave about a 2" lift and am swapping in 3.73 gears. Thats all I really have in the line of "upgrades". Now I'm just fixing rust and making a kick butt motor.
    Right out of the box though....
    Tune the sucker up!
    K&amp;N Filter
    Complete Fluid and Filter Change
    Grease everything
    yes, i know those aren't really mods but if you just got the thing, don't trust the story of anyone you bought it from.
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  19. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    First mod: Mud bath
    Second mod: Strap
    Thrid mod: BFG M/T Tires
    Fouth mod: Mud bath
    SK-15
    J**P...it's whats for dinner!
    Roads? Where we're going, we don't need any roads!
    If it wasn't for bad luck I would have no luck at all!!
  20. jms
    jms 1/2 ton status Author
    Jan 24, 2001
    1,683
    Reliability first: in my case radiator, decent tires, u-joints, all fluids + some gaskets replaced, battery.
    First upgrade mod: 4.10 gears and a locker for the rear.
    <a target="_blank" href=http://desertrider.net>http://desertrider.net</a>
