first time blazer lift
Discussion in 'The Garage' started by sandypants, Aug 9, 2006.
  1. sandypants
    sandypants 1/2 ton status
    Nov 17, 2005
    228
    spangdahlem AFB Germany
    im lifting my first and doubt last blazer. i currently have 33 ATL on it with stock sagging leafs and worn out rancho shocks plus my body mounts need to be replaced (know where to find any?). the rest of the truck is in great shape and i want to go big but not spend all my life savings as well as have great movment and function. i was thinking about 4 ez ride lift to start then a shackle flip front and rear-2 frount 4 rear then go to 35's. the rest of the truck is stock and is a manual. how does this set up sound to you pro's and what would you recomend thanks for the help. p.s. be sure to show pix of results-sandypants
  2. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I would start by replacing the body mounts as stated.
    You might be able to find a used set of front 4" springs and a used shackle flip.
    But First and foremost, get a membership to CK5:D
  3. 88-3/4t-bad boy
    88-3/4t-bad boy 1/2 ton status
    Nov 27, 2005
    150
    Texas
    4 inch is big?
  4. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    I think the Tuff Counry 4" in front and ORD shackle flip with stock springs in rear is a good setup. You will always degrade the ride when you start lifting but 4" isnt bad.
    Click on my link below and see what I did for my first lift
