first time gear setup...here I go!
Discussion in 'The Garage' started by wetbackZO, Oct 29, 2006.
  1. wetbackZO
    wetbackZO 1/2 ton status
    Jan 30, 2006
    113
    Las Cruces, NM
    aight people, I am going to do my first differential. I just need to know which tools are essential. I already have a hydraulic press and all the hand tools. Hope harbor freight has all I will need, he he...thanx in advance.:D
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
  3. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    What he said, and a set of dial or digital calipers is nice for sorting through different shim thicknesses for when/if you need to change backlash, pinion depth, etc.
  4. wetbackZO
    Jan 30, 2006
    113
    Las Cruces, NM
    great article, thanx...
  5. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,014
    845
    Pinckney, MI
    rent a decent dial gauge... dont use hf stuff for something sooo important
  6. wetbackZO
    Jan 30, 2006
    113
    Las Cruces, NM
    ok, then sears it is...
    so far I got a nice digital caliper...getting there....
  7. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    after you collect your tools, be patient with the install. There is only one right way these things go together, proper setup is crucial to the longevity of the gears. You may have to run patterns till the cows come home but in the end it is worth it because you know it was done right. You might get lucky and only have to run 2 or 3 patterns or you may end up running 7 or 8 patterns until your satisfied with the way the pattern is set. Just remember to read, read, read, and dont be afraid to ask questions on here, theres a couple of guys on here that are invaluable resources when it comes to help for setting up gears. Good luck once you get moving, post pics of your pattern when you think its ready. :thumb:
  8. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Which one of your fleet are you working on (which diff)?
  9. K5dreamer
    K5dreamer 1/2 ton status
    Mar 14, 2005
    3,084
    Alexandria, Va
    my only peice of advice on this, because ive only done it a few times myself, is if at all possible, have someone who is experienced with this job at least look over your shoulder. setting up a rear diff is more like tuning a musical instrument rather than just bolting on a cylender head and torquing the bolts correctly. expect to install, test, remove, reshim, and reinstall the whole thing several times before you get it just right.
  10. 77crewcab
    77crewcab 1/2 ton status
    Feb 9, 2004
    1,620
    Lubbock, Texas
    Not nearly as hard as everyone makes it sound. The HF dial indicator and magnetic base stand along with a dial caliper, paint marker and some axle bearing grease and you are pretty much good to go. I haven't looked at the Haynes manual to see if it has sufficient instructions for the pattern and such but will check it and see how it sounds if need be I can scan some better general instructions to send you that will help understand how to set the pattern, backlash etc.
