First time poster, transfer case question...
Discussion in 'The Garage' started by joel300zxt, Nov 17, 2005.
  1. joel300zxt
    joel300zxt Newbie
    Oct 19, 2005
    Omaha, NE
    Hey guys,
    I have a question. I just bought an 84 Jimmy for cheap. The drive train is solid except for the fact that when put into 4 wheel drive high it will not stay engaged. The previous owner rigged a bungy cord setup to hold the shift lever in place. This seems to work pretty good, although it is a little ghetto in my book. I was just wondering what would cause this problem and what kind of solutions there may be. This is my first time posting, so if I let out some crucial info or have just made an ass of myself for not following etiquette please accept my apologies.
    Joel
  2. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    Body lift or transfer case lowered causing the shifter to hit sheetmetal or shifter needs adjusting.
  3. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Could also be a bad detent ball/spring in the t-case... Does it even have a body lift....or any kind of lift on it?
  4. JIMs70K25
    Dec 31, 2001
    524
    Chesapeake, VA
    forgot about play in the linkage.
  5. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Make sure the linkage is solid and not hitting anything.
  6. mrhoes
    mrhoes 1/2 ton status
    Jul 20, 2002
    123
    Austin, Texas
    Your transfer case might need a rebuild, mine used to pop out of 4 high and I adjusted the linkage and it helped some but it still did it. When ever I get my K5 running again I am going to rebuild the t-case. There are some plastic pads on the shift fork and when they wear out it makes it hard to shift into 4wd.
