Fit 35's with 4" lift?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JTB, Dec 12, 2000.
  1. JTB
    JTB 1/2 ton status
    Dec 5, 2000
    192
    CA
    Fit 35\'s with 4\" lift?
    I have a 70 Blazer and Im wondering if I can fit 35's with 4 inches of lift without major trimming, or without any trimming. Thanks for the help!
    Don't drive it unless it says Chevy!
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Re: Fit 35\'s with 4\" lift?
    From what I've read, you can depending on the net height of your lift and the brand of 35's you get. SOme run bigger adn some run smaller. But for pavement driving you should be "ok", except for full turn. Minor trimming I'd think you'd be good to go, less you get into some deep flexing.
    I miss my Ex, but my aim is getting better!
    http://mccordhouse.freeservers.com
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    I have a friend that is running a 4" lift with 35" Kelly DTR's on a 3/4 '71 P/u..... He didn't trim anything, and the dont hit.
    HTH
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  4. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    Most likely you will need some trimming, but not major stuff. If you have a flexy suspension you will for sure need the trimming. I put 35's on with a 4 inch Superlift softride, and usually left the sway bar hooked up (even though I have an ORD disconnect!) because the tires would hit so hard at full flex while turning. And that was WITH fender trimming (although obviously not enough!) If I trim any farther I will be cutting the inner fenderwell and have a hole to the cab - don't want to do that. So last week I returned the Superlift 4"ers under warranty (they were sagging after 5 years of abuse, and they have a lifetime warranty!) and got the 6" springs for $20 more! Should cure most of it... Oh and by the way, that was with BFG Mud T/As, which measured an actual 34.5" when inflated...
  5. BUDDY
    BUDDY 1/2 ton status
    Apr 28, 2000
    744
    Midland, TX
    I have a '72 and fit 33's with NO lift. They did rub a little in the back of the front wheelwell but not anywhere else. I've got a 3" bodylift on it now and I'm sure that 35's would fit it no problem. The 1st gen's have a larger wheelwell opening and it's radiused (sp?) at about a 38" diameter. 35's should fit with a 4" lift no problem.
    HTH,
    Buddy
    I've got my dream truck and it's a 72 K-5 that is getting there!!
  6. JTB
    JTB 1/2 ton status
    Dec 5, 2000
    192
    CA
    Thanks Buddy, and everyone else who replied. Time to buy some 35's. If you have a Four Wheel Parts near you, they have a buy 3 get one free deal on BFG's and Pro-Comps.
