fittin 35's
Discussion in 'The Garage' started by tecton, Jun 10, 2003.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    fittin 35\'s
    my truck must have a body lift on it
    but i can fit 33x12.5 with like an inch of fender corner cut out
    if i got me a 4 inch suspension lift...could i fit 35's no prob?
    makes sense...2 inch taller tire, 4 inch taller suspension
  2. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Re: fittin 35\'s
    How much body lift? I've seen 33's on no lift no cut fender trucks. w/ a 4" I cleared 35's fine w/ a little rubbing offroad, but not much. If you already have a small body lift 1"-3" an additional 4" suspension would definately clear 35"s. Check to see if theres a gap between your body and the frame supported by "pucks" Then youll know you have a body lift.
  3. tecton
    Dec 1, 2002
    1,553
    WV
    Re: fittin 35\'s
    im pretty sure i do...1-3
    ill measure today
  4. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    Re: fittin 35\'s
    i run 5 inches of lift and 37s. i had to cut a lot of fender but nothing drastic. i mean the cut didnt interfer with my floorboard at all. i also have f*rd shock towers and 9012s so the tire gets up there pretty high but it never rubs.
  5. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    Re: fittin 35\'s
    I could flex out my K5 all the way w/ the sway bar connected w/ 33s and no lift but when the swaybar came off I would rub
  6. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Re: fittin 35\'s
    I am running 33's with a 4" and have miles of room, I would think 35's would fit without any problem. My front fenders have been trimmmed a small amount so I can fit 35's when I buy tire next.
  7. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Re: fittin 35\'s
    I run 33's on stock suspension, no body lift, and no trimming. So with a 4" lift 35s are doable
  8. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Re: fittin 35\'s
    Check my pics in the Member's Gallery, 35's and no lift /forums/images/graemlins/thumb.gif
  9. swampblazer
    swampblazer Registered Member
    Mar 31, 2003
    49
    mass, u.s.
    Re: fittin 35\'s
    lets see
    my buddy has a 89 Jimmy with 35's and a 1'' hockypuck body lift. dont ask, he is a pot head. he had to cut the fenders a bit. im running 33's with fender trimming no rubbing ever. and a friend has a 83 k-5 with 4'' sys. lift and had 35's and doesnt hit. little trimming!!
    peace luke
  10. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Re: fittin 35\'s
    It all comes down to how much flex you have. I was running a 4" lift with a 3" body lift and it looked like I had gobs of room. Took the sway bar off and sliced up a tire pretty good. And I am running 35" tires, Rancho springs and Rancho RS5000 shocks, so nothing trick as far as my suspension goes. Be on the safe side and cut a little for good measure, esp the corner hanging down by the doors. /forums/images/graemlins/thumb.gif
    couple of pics http://www.geocities.com/trcksR4ME/fendertrim.htm
  11. bangedup
    bangedup Registered Member
    May 17, 2003
    21
    Alberta
    Re: fittin 35\'s
    I rub on 33's,4 suspension lift and 10 rims with 4 1/2 b/s
    on full compression with the sway bar off. A little lower
    fender trimming is needed .
  12. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    Re: fittin 35\'s
    yeah, the tire literally fitting in the fender on flat pavement and the tires REALLY fitting are two different things. Gotta max out flex to know if it'll really "fit". Back when I have 4" of spring lift and 1" of body lift, I could rub 35s when the sway bar wa disconnected and I flexed it. Fender trimming solves all that though. /forums/images/graemlins/grin.gif
    with the anti-sway bar attached, 35s seem to generally fit on k5s with 4" of lift... but like i said, no sway bar + flex = ur prolly gonna have to trim a lil.
    j
  13. bigjbear
    Feb 18, 2000
    13,973
    452
    Marietta GA
    Re: fittin 35\'s
    1) just look at your truck see if it has a BL on it
    2) how tall are those 33s? how wide? don't trust the sidewall
    3) SEARCH, its only been covered a 1000 times
  14. 76SILVERADO
    76SILVERADO Registered Member
    Mar 1, 2003
    52
    AZ
    Re: fittin 35\'s
    I rub with the sway bar disconnected with 6 in and 35's.
  15. mudtruck
    mudtruck Registered Member
    Apr 2, 2003
    14
    pa
    Re: fittin 35\'s
    You should have no problem running the 35 i am running a 4" lift and i am clearing 39.5's with a little bit of trimming.
  16. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    Re: fittin 35\'s
    wow, i'm glad i looked at this.my truck was used mostly in mud.now i love rock climbing(i even have two big ones in my front yard),after the re-build my trucks has a 6 in. lift and 36 x 12 in. tires and i was going to get rid of the sway bar.
