Fitting 15" on Dana 44 3/4 ton
Discussion in 'The Garage' started by IDGMC, Mar 6, 2006.
  1. IDGMC
    IDGMC 1/2 ton status
    Feb 18, 2000
    150
    Idaho
    I read the article on grinding a dana 60 to fit 15" 8 lug rims. Would the same grinding be required on a dana 44 3/4 ton?
    I scored a gm14 bolt and dana 44 off a 76 chevy to swap in my 91 k5. I pulled the rear cover on the 14 bolt. I think it has a limited slip?? its kind of a cone shape coming thru the ring? would that be a factory limited slip? and does it require special gear oil?
    Thank
  2. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    no grinding at all. 80/90 gear oil
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Yes you still have to grind the 3/4 ton D44 or 10 bolt. It is not as extensive as the D60 though. It depends on your backspacing. 4.25 you have to grind a bit. 3.75 some and 2.75 many people dont have to grind at all:D
  4. IDGMC
    Feb 18, 2000
    150
    Idaho
    really....cool! what are my options for 15" 8 lug rims? and what backspacing 4"?
  5. IDGMC
    Feb 18, 2000
    150
    Idaho
    So what backspacing would you guys recommend? I'm running 33X10.5r15 bfg's I'd like to stay close to stock....what is a stock wheel back spacing?
  6. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    That depends. I like the 4.25 beause it's less stress on the ball joints, and wheel bearings, but you have to grind more. The 2.75 you don't have to grind at all I believe, but that is more stress just hanging off the end of your axle. With 33's it's prolly not that big of a deal. If you are like anybody here the 33's will only be a stepping stone:D The 3.75 would be a happy medium. Give it a little wider stance, and you should only have to grind a little bit.
  7. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    This is a 3.75 BS 15x10 rim and a 12.5 wide tire. I have 4.25 BS rims now and they sit in just a hair more about .5" to be exact:D
  8. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I'll 2nd what Brian said. Here is a pic of what and where I had to grind to fit 15 X10's with 4.25" BS on my 8-lug D44.
    I had to grind on the caliper and grind/reshape the caliper bracket.
