fitting 33" tires
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by blazingjesse, Apr 20, 2001.
  1. blazingjesse
    blazingjesse 1/2 ton status
    Mar 13, 2001
    159
    kayenta, AZ
    fitting 33\" tires
    Does anybody know what brand a 33" tire would fit on a stock 71 blazer? I'm thinking of putting on 2in leafs in all the corners. What does all this envolve? longer shafts? dropped transmission support, longer shocks, i need all the details. If i do this what would be the biggest tire i could put on?
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Re: fitting 33\" tires
    2" lift will fit 33X12.50s comfortably. 35s will not fit with less than 4". No driveshaft mods will be required with a 2 - 2 1/2" lift.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  3. 72_blazer
    72_blazer Registered Member
    Feb 12, 2001
    39
    wichita ks usa
    i have 33's no lift does great no rubbing
    72 blazer 350 h.p.350 sm465/np205 33/12.50/15(soon to be 406 o yeah)
  4. blazerman
    blazerman Registered Member
    Apr 12, 2001
    44
    Sacramento, CA
    I also have 33's on my 72, ans they fit good no lift. However, there is a little less room then I would like for wheel travel on the serious trails.
  5. Robert
    Robert Registered Member
    Feb 23, 2000
    8
    Pagosa Springs and Colorado Springs Colorado
    I have 33X9.50 BFG AT on mine, no prblems
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I have warn down 33's on mine with a 4" lift. The front doesn't rub but the rear does.??? It all depends on how hard you drive it. I don't think that brand matters much (except that some are smaller than they say). Wheel offset makes alot of difference.
    '71 Blazer CST with alot of rust
  7. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Depends on wheel size and offset. A friend has a stock height '72 with 8" Rally wheels on it and 33x12.50" tires on it and they fit for the most part (until he articulates it, then they hit). I have problems on a level road, turning the wheels from lock to lock with stock ride height and 32x11.50" tires on my 15"x10" wheels.
