fitting big meats
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by hd44blazer, Jul 18, 2006.
  1. hd44blazer
    hd44blazer 1/2 ton status Premium Member
    Dec 21, 2005
    651
    172
    Antioch, CA
    anybody have pics of a stock suspension '79-ish p/u with 37's stuffed under it? cause i have both layin around and just wanted to see what it'd look like before I attempt it.
  2. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
  3. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    these are 38s but you get the idea. The suspension was not touched
  4. edreid
    edreid Registered Member
    Dec 14, 2005
    19
    so cal
    38's on stock suspension did you have to do any cutting???
    and if so what did you cut i want to put 35 on my 88 stock suspension cause i need tires and dont have money for a lift yet so i am thinking of cutting but i do som mostly light towing and dont want them to rub if the butt is down. thanks
  5. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    I had 36" tsl's with no suspenion mods and i had to cut the hell out of the front and rear portions of all the wheel wells, like 5 inches in some spots. Looked like a real wheeler after that but is still rubbed in the rear on the inside of the bed at full stuff (which is like 3 inches on stocky suspension) heres an old pic
  6. blazinzuk
    Dec 20, 2002
    17,412
    3,799
    here are the cuts we made on a 84 blazer to fit 36s (most normal 37s will be the same heigth as these 36s) These tires measured 36.25" on the truck. Best advice cut a little find somewhere to flex it out and then go back and cut some more if need be. On the picture of the rear it turns out we didn't need that cut it would have cleared just fine with no cuts. The front did not rub but came very close
  7. hd44blazer
    Dec 21, 2005
    651
    172
    Antioch, CA
    here's what i ended up with....I only cut the front because I'm not planning on wheeling it, I just had the tires laying around until I finish the suspension on my '93 K_Blazer and was getting tired of driving around on 30" streeters,...nothing rubs under normal driving conditions. The setup is as follows half worn 37x12.50 Swamper SSR's wrapped around 16x10 steel crawlers with 4"_b/s.
  8. carol ladue
    carol ladue Registered Member
    Jul 9, 2006
    12
    sacramento
    nobody beats you meat:p:
