Fitting thread id.
Discussion in 'The Garage' started by tarheel, Mar 17, 2004.
  1. tarheel
    tarheel Registered Member
    Apr 11, 2003
    65
    GA
    i'm pretty familiar w/ standard and metric threads and how to identify them...but what about these "-an" fittings. the place i see them the most is in my summit catalog on the fuel fitting stuff. what's different about them, and do they make a guage to id. them?
    tia,
    matt /forums/images/graemlins/dunno.gif
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    "AN" meaning army/navy where the first user's to spec em, year's ago.
    They are a straight thread like a 37* JIC fitting but they won't interchange.
    I don't know if anyone make's a gauge to measure the thread count, ask at a local hydraulic supplier, they carry them too. /forums/images/graemlins/grin.gif
  3. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    they are in 16ths
    -4 is ~4/16ths etc
    are you sure they arent a swap for 37* JIC?
  5. tRustyK5
    Jul 23, 2000
    36,166
    1,363
    E-town baby!
    -4,-6,-8 etc is the hose size in 16th's, doesn't tell you much about the thread itself. I can't recall if JIC threads match up or not, but i know JIC won't seal up to AN stuff.
    Rene
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    JIC
    -02 5/16-24
    -03 3/8-24
    -04 7/16-20
    -05 1/2-20
    -06 9/16-18
    -08 3/4-16
    -10 7/8-14
    JIC and AN look the same to me
    they share thread size, pitch, and flare angles
    the hydraulic companies use the terms interchangeably IIRC
    if you can find a -6 JIC to -6 AN adapter please shoot me a link, I love to learn
    I used Goodridge and Aeroquip AN adapter fittings recently and the JIC seems to be sealing pretty good on them
  7. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    JIC has a looser fit thread than AN spec fittings. All the dimensions are the same (AFAIK) but held to looser tolerances. I have heard that up to -6 there is no problem but when you get into the higher sizes (a friend was using -12 on his shocks /forums/images/graemlins/eek.gif) that the JIC won't seal.
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    good thread!
    fnally someoen explained and showed what AN is and how it works
    now what about JIC ?
    what is that ?
    thanks /forums/images/graemlins/thumb.gif
  9. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    JIC is 37 degrees in both male/female end's. Female cap to a male fitting. Or female nut [on say a 45 degree fitting] to a male fitting. /forums/images/graemlins/grin.gif
