fitting TSL 42's on a K5
Discussion in 'OffRoad Design' started by blk87K5, Dec 30, 2001.
  1. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    fitting TSL 42\'s on a K5
    What is involved in fitting 42" TSL's on a K5 with a 6" susp. and a 1" body? I know there will be MAJOR trimming and probably losing the inner fender liners. I had also planned on moving the front axle forward 1" to help with cab clearance. What problems will I run into? I would like to know all of the little problems that might arise.
    '87 K-5 w/ 350 TBI, 700r-4, Atlas II, D60 & 14Bolt, 6" susp., 1" ORD body, 35" Claws
  2. blk87K5
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Re: fitting TSL 42\'s on a K5
    Stephen-How did you modify the front marker lights for the fender trim?
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    we went over some of this on the phone, basically I think you're on the right track. No matter what it's going to take some messing around with, but shouldn't be too bad with the list of mods you have.
    The markers are just cut in half, they're non functional at this point, no bulb in the back.
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
  4. bradley J.
    bradley J. Registered Member
    Sep 12, 2005
    15
    snohomish,wash.
    fitting 42`s
    they`ll fit,i`m runin 40"bogs w/4" lift.
    brad
  5. blk87K5
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Holy old post. That had to be one of my first posts. I cant believe this is back at the top. Just goes to show how much we all mature with our wheeling rigs, and ORD can take credit for a lot of that with me.
  6. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    WOW!!!! 2001
    I wouldn't have even considered buying a Blazer back then. Oh how life makes you change.
  7. bradley J.
    Sep 12, 2005
    15
    snohomish,wash.
    SORRY,
    my bad, i`m still kinda new.
    didn`t see the date, just jumpt in:doah:
    brad
  8. blk87K5
    Dec 26, 2001
    1,290
    Lubbock, Texas
    No biggie. You bringing this thread back to the top made my morning.
  9. vtblazer
    vtblazer 1/2 ton status GMOTM Winner
    Sep 30, 2003
    2,471
    Central VT
    So how did it all turn out? Any pics?
    Now I'm curious...
  10. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    Yeah me too, I want to run 40's or 42's. I think Im probably around 6 inches of suspension with 1 inch body and pretty flexy springs.
  11. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    ive got 9" of lift and have 42's
  12. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Koldsimer runs 42s with a 6" and 1" body.
  13. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    I was running 44's with 6" suspension and no body lift for a while. It rubbed in a few areas that trimming wouldn't fix... such as the cab and the inner wheel wells when I had them in the rear. The new suspension will be 52" springs with a zero rate pushing the axle foreward 1.5" up front and the 64's I had with whatever size block/zero rate it takes to level them with the front. Overall I'll have roughly a 115" wheel base from my K5 chassis so my tires should be well out of the way of the cab this time around.
  14. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    This is 44's on 6" of suspension lift.
  15. 54inches
    54inches 1/2 ton status
    Feb 9, 2004
    1,535
    Houston, Texas
    My questions is how do I fit 50's on my Burb?
  16. nova
    nova 1/2 ton status
    Mar 9, 2003
    285
    Laporte, IN
    Just rip the body off and your set!!:hack:
  17. 54inches
    Feb 9, 2004
    1,535
    Houston, Texas
    no that would be the way of a crawler...i have more class than that.......he he haw haw hooooooo hooooooooo
  18. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    15" lift and cutting would probably do it for 50's
  19. 54inches
    Feb 9, 2004
    1,535
    Houston, Texas
    probably NOT....
  20. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    How does this 2001 post keep coming back to life???
