Fix a flat, Replacement for spare?
Discussion in 'The Garage' started by anatomiczero, Oct 28, 2003.
  1. anatomiczero
    anatomiczero 1/2 ton status
    Jun 26, 2001
    418
    Washington
    I run 31" tires right now and don't want a spare inside. Will fix a flat work?
  2. Stroked72Blazer
    Stroked72Blazer 1/2 ton status
    Nov 9, 2002
    352
    Little Rock, AR
    If a rock makes a considerable tear yur stuck. If its a small hole then fix a flat will ruin your tire. FAF works by disolving the insid of the tire so some of it moves to fill in the hole. If its doing that imagine what its doing to your sidewalls.
  3. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    Fix a flat will make your tires unbalanceable, and will also eat your rim and ruin your tire. You can always run the self sealing tires, I know uniroyal makes em and I think so does goodyear and michelin.
  4. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Id never use that fix a flat it makes a huge mess and eats away at the tire over time. Mainly its just a big mess when you have to fix them and such, I hate fixin tires with fix a flat in them /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Yeah to what everyone else said! If you do use that crap. Get to a tire shop and have the tire fixed right ASAP. Dont leave that stuff in there very long.
    A spare is way better. Fix a flat only works on small holes and would do you no good if you bent a rim and unseated the bead.
  6. anatomiczero
    Jun 26, 2001
    418
    Washington
    Thanks everyone, I guess I'll just leave the spare inside. Don't really like the look of it outside.
  7. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    i always thought it puts some kind of expanding foam inside the tire that dries coming out the hole....am i mistaken? or is it something else
