fix for screw hole in roof
Discussion in 'The Garage' started by mini_mull, Feb 17, 2005.
  1. mini_mull
    mini_mull 1/2 ton status
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    I was putting in a new headliner today and had everything out (bare metal inside on roof), then had to go pick up my niece from school, anyways, it started raining and we noticed that the last time someone replaced the headliner they used a screw that was too long and went through the crossbar and the roof panel. We could see daylight through the roof! I'm going to have the roof rack and other stuff taken off and holes filled before painting this summer, but need to do something to fix it until then. What's the best way to fill a hole the size of a screw so I won't end up with a wet new headliner and rust? BTW it will have to endure the first half of the AZ summer so anything that melts is out of the picture, or will have to be replaced come hot summer. Oh, and I don't have access to a welder or the know-how to use it. Please help. Thanks.
  2. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    i was goping to say welder. lol
    how about jb weld?
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Maybe some clear silicone for now?
    To be honest, the only way to "really" fix it is to weld it shut and grind it down prior to painting.
  4. mini_mull
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    What's a jb weld? Any specific kind of silicon? Could I just keep reapplying the silicone for 4-6 months until I get the body and paint work done? Would silicon melt in the sun? Thanks for replying so quickly. I appreciate the help. This headliner is more of a headache than I bargained for thanks to the moon roof making the front half impossible to have a one piece headliner board. Of course, there always has to be something to complicate every project.
  5. Can Can
    15,552
    136
    If you're planing on taking the truck in for paint/bodywork within 6 months, silicone will be fine. Just go to the hardware store and tell the counter guy that you need a clear exterior silicone. It's the same stuff you use to seal doors and windows from the outside, so no, it won't melt.
    If you apply it properly you should only have to do it once.
  6. flatline
    flatline 1/2 ton status
    Sep 9, 2004
    167
    Cincinnati, Ohio (area)
    go to your local autoparts store and ask them for rubber push in plugs, I use them on a lot of project, just dab some silicone on the tip and when you push it in it will seal. then when you wanna fill it perm. pull prep paint!
  7. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    Put a screw in it with a little silicone or caulking....
    Or get a screw with a rubber grommet like we use to put sheeting on buildings , no leaks
