Fixed 2-24-04 !!!!! ** Who Runs a CV Shaft **
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by pauly383, Feb 17, 2004.
  1. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Cv issues are gone... Thanks to all/forums/images/graemlins/thumb.gif
    original post:
    I just installed a CV shaft on my 83 and have a couple questions: 1. Do they make any noise on initial takeoff? 2. You are supposed to make it point towards case right ? 3. Does shackle flip make a difference ? I may have spring wrap even with 305 and highway gears. Any help appreciated. Search doesn't seem to narrow it down for me . /forums/images/graemlins/k5.gif
    I guess what I am getting at is should I shim it down a bit to allow it to run straight under power?
  2. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Re: ** Who Runs a CV Shaft **
    I have CV shaft, and not one problem. I still have my pinion angle within 2* of each other.
    Bill
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Thanks /forums/images/graemlins/k5.gif
  4. 87GMCJimmy
    87GMCJimmy 1/2 ton status
    Nov 21, 2001
    582
    Phoenix, AZ
    I have one from High Angle. No problems at all. I did order a degreed offset shim from AZ-Kickn' to correct the pinion angle. I'm running the ORD 4inch shackle flip with the axle moved back 1.5inches.
    Mike
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Thanks Mike. So where does your pinion sit now. Did you point it at transfercase, or a little down so it comes up with torque?
  6. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Do you have any pics of your rig that would show the rear tire location in the wheel wells since you moved the axle back 1 1/2"
  7. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    I have a High angle CV shaft and my pinion is 2* down from facing straight at the t-case. This is what Jesse told me to do. I just cut off my old perches and welded in new ones with the extra inch of hieght already in it. I also moved my axle back 1" and I have the 4" shackle flip with stock springs. Here is how my axle sits in the well with it flexed.
  8. Jays Beast
    Jays Beast 1/2 ton status
    Aug 7, 2002
    538
    Chandler, AZ
    Hey Paul truck looks good /forums/images/graemlins/thumb.gif Like others have said having the pinion down a couple of degrees allows for driver and/or passenger weight. If pointed straight at it will point the pinion above the tcase when there is a load on the suspension like people, camping gear. Shim it down a little and should be ok. Also where did you get a cv slip shaft localy?
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I got it at the place some guys hate and some guys love, 2417 w. lincoln 602-253-8006 arizona drivelines & axles . 295.00 plus tax . I picked up some shims tonight for 11.99 , I went 4* since my rear is pretty soft now and its real straight. . I don't have a big enough jack here yet so I am stuck tonight. You want to help? Oh and how long are Sub e-brake cables? Was thinking different model may be longer. /forums/images/graemlins/thumb.gif
  10. 85scottsdale
    85scottsdale 1/2 ton status
    Dec 22, 2003
    283
    Lewisville, NC
    I had a problem with my driver side e-brake cable on my K10 being a little to short. Is that the same problem your having? I haven't found a solution to it yet, would like to get it hooked back up, so let me know what you find out.
  11. Jays Beast
    Aug 7, 2002
    538
    Chandler, AZ
    My e-brake run down driver side and then spliting to the two rear wheels and looked to be much longer than your cables are. I think that you could modify yours to use the suburban e-brake cables. Have not had a problem yet with mine. /forums/images/graemlins/whistling.gif Time to buy a high lift,/forums/images/graemlins/woot.gif cause can't get the rear off the ground with out it good excuse to tell the wife /forums/images/graemlins/ignore.gif Sorry I would like to help but don't have any time for a week or more. /forums/images/graemlins/frown.gif
  12. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    [/ QUOTE ] /forums/images/graemlins/yikes.gif I needed one a half hour ago when she cornered me and found out about the CV-shaft. She's cool though as long as I put it back. I think she is already getting me a high lift for my birthday (3-2). /forums/images/graemlins/thumb.gif
  13. 87GMCJimmy
    Nov 21, 2001
    582
    Phoenix, AZ
    Sorry it took so long for the pic but here it is. Rear axlw moved back 1.5 inches.
    Looks like it's where it's supposed to be.
    Mike
