Fixed my fuel gauge finally
Discussion in 'The Garage' started by tRustyK5, Apr 24, 2005.
  1. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Replaced the guage cluster housing. Swapped all my old guages into a spare cluster I had in storage.
    I guess the printed circuit board was messed up somehow on the old cluster, because now all my dash lights work and the fuel gauge too. :) Having a working fuel guage in a diesel truck is pretty important, luckily I never ran it out of fuel in the last 6 months or so.
    Rene
  2. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    congrats....
    i've been dealing with it for about a month now and its a nuisance... tho its been MY decision to drive around with no dash while i transform the interior...
    and i mean no dash at all... ;) no speedo doesn't bother me, just losing track of fuel...
  3. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I ran like that for a couple of days...it's weird. I don't have a dash pad on it anymore since the cage went in, so it's a little ugly. At least the cluster and the plastic overlay still fits up.
    The fuel gauge was annoying, but I could keep track of the mileage. Having no dash lights ticked me off though.
    Rene
  4. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Good deal. What were the symptoms, for those of us that haven't been paying attention :blush: :grin:
  5. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Fuel gauge worked intermittantly after the cluster had been re-installed for the 5th or 6th time. Within a week the guage went pegged overfull and just stayed there. The dash lights quit about the same time...so i felt it was related to the cluster itself rather than the sending unit.
    I also knew i had a spare cluster lying around, so if i was wrong I only wasted $0 and 20 minutes of my time.
    I had a previous problem with the GM clusters. My previous cluster prob's were when the only two guages working were the speedo and the fuel gauge. No temp gauge, no oil press guage and no volts guage. Took that cluster apart and swapped in some other gm guages I had and everything was cool.
    It pays to keep 3 or 4 gauge clusters around...but now I have to find a few more for the next time :crazy:
    Rene
  6. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Good info, Gracias :)
  7. savagek5diesel
    savagek5diesel 1/2 ton status
    Nov 20, 2003
    310
    Redding California
    I've been having a similar problem, but if i hit my guages hard enough the lights usually come back on. but a couple days ago the fuel light went out and has yet to come back on. also the oil pressure guage hasn't worked since i bought the truck. so i guess this problem is just fualty circuit board or bad gauges?
  8. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    I've had a "half tank" for 3 years now....
    how do i tell if the sending unit or gauge is bad, or is there something else?
    I've had the sending unit out and the float wasn't stuck but that doesn't mean the sending unit is ok.
  9. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    The intermittant lights are pretty easy to fix. Remove the twist bulb holder and pry the contact tabs up a little, then put it back in. A little scotch bright on the copper works good too.
    DW17, might just be a bad guage. I've had quite a few dead guages in these clusters over the years. Usually if a sender goes bad the guage will be pegged full or empty. If the needle doesn't move at all I'd bet guage.
    Rene
  10. dyeager535
    26,982
    191
    Grounding the pink sending unit wire with the key on should move the gauge. If it doesn't, gauge issue. If it does, sender issue.
    Of course, the problems could be compounded, I had both a bad fuel gauge AND sender, which made diagnosis interesting. Bad readings from sender, bouncy gauge because the gauge was bad.
    I agree with Rene, if it doesn't move at all, it's probably not a sender issue.
    After my recent fun with rewiring my gauge setup for the later electric speedo, I can tell you the printed circuit that "drives" the lights and all the gauges is very simple. All gauges essentially have one wire that comes from a sender or switch (headlight dimmer for lighting, oil, fuel) that is on the printed circuit board, all the other "circuits" on the board are simply + or -. '90-91 PCB's are pretty cool, the + and - is actually embossed in the copper, and all gauges/lights share the same +. If one connection goes bad, all will lose power or ground, or you will simply lose the individual input for whichever gauge. I'm having to learn WAY too much about how these things work from this swap. :) At least I hope that gives a bit of understanding of how the gauge cluster works. It's not a big mystery. The fuel gauge for instance only has one specific wire for it...in my case it's the same pink one that comes off the tank.
    Only problem is that you've got to remove the cluster to get at the PCB, but no problem in my case, I knew there was a reason I haven't yet installed the dashpad.
