FIXED NOT THAT EXPENSIVE** SECOND LIFT ISSUE **
Discussion in 'The Garage' started by pauly383, Feb 15, 2004.
  1. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Getting CV shaft thanks for replies
    OK Heres the angle of my pinion after my shackle flip (echobit). Looks perfect if I had a CV shaft. Any ideas how much shim I may need . Or does any local members (AZ) have a used CV shaft or knows what shop I may use to install one on my shaft for little cash? I am vibrating from low speeds on up with it KINDA getting better at higher roadspeeds. I don't wanna chuck a joint ( P.I.T.A, though I carry spare joints ).
  2. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    Re: ** SECOND LIFT ISSUE **
    not to hi jack but Im about to install mine to and did you run into any problems and did it move your axle forward any
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I don't think it moved forward much more , the distance between axle pad and front spring eye mount ( fixed distance ) didn't change. It really just moved the pinion up. I could comprehend it moving forward just a tad as the spring lowers in the rear it hinged forward , but not more than 1/2 inch for sure. /forums/images/graemlins/k5.gif
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have been running mine like that for two years without issues.
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    You are lucky then. I cant take my whole dash rattlin' because of vibration. I need it to drive somewhat normal so I can relax and have less thing to worry about from a 20 year old truck. I could take a vibe at 70 mph ( was like that before ) but not a 10-45 mph /forums/images/graemlins/k5.gif
  6. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    It doesn't have to be a "guess".....just borrow an anglefinder and take a measurement of the upper joint and compare it to the lower one. (Subtract the big number from the little number, and that will tell you what size shim you need! /forums/images/graemlins/woot.gif) IIRC, if you can get them within 1 - 2 degrees of each other, that's generally enough to cure the vibes.....
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Great , thanks for the tip........HMMM I wonder who in town has an anglefinder they want to bring by my work tommorrow in AZ. /forums/images/graemlins/k5.gif
  8. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Paul, I have the same issue with my joint angle. I just let it vibe and replace the t-case joint every other oil change. It is a pain so I would reccomend shimming it slightly also. Or give HAD a call and get a cv shaft sent out.
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    So much commotion from it on way to work, decided to buy a CV shaft. Thank god I got my credit clean. Just bought a CV shaft local should have it before dayend. I can and have done joints, but its like pulling teeth, you need to do it but don't want to /forums/images/graemlins/thumb.gif
  10. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    He couldn't wait for me to head over there today and shim it for him for free, he likes spending money,,, /forums/images/graemlins/yikes.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif
  11. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Its not the money , its the GUESSING on angle, you were just gonna put on the ones you have when we need an angle finder /forums/images/graemlins/thumb.gif
    Right the first time and no more conversion joint, peace of mind and less breakage. /forums/images/graemlins/waytogo.gif Besides who cares get your truck ready so we can wheel /forums/images/graemlins/thumb.gif
  12. 4xcrazy
    Oct 31, 2003
    9,472
    5
    SO technical, i believe it would have worked out, but no biggie, it's your money, and your explaining to the wife... /forums/images/graemlins/whistling.gif /forums/images/graemlins/yikes.gif
    /forums/images/graemlins/grin.gif
  13. 4xcrazy
    Oct 31, 2003
    9,472
    5
    SSSHHHH, he's gonna keep it a secret,, /forums/images/graemlins/grin.gif
    /forums/images/graemlins/whistling.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/whistling.gif
  14. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    OK, the angle finder is available at Sears or Home Depot for about $10. Shims are less than $20/pair and are probably availably locally. Now I'm not saying that the CV shaft isn't a better solution, but you could have bought the angle finder, measured, bought shims and had it all installed before you will get your new driveshaft.
    You probably would have needed 6.5-8.0 degrees of shim after the shackle flip, depending on the position of your T-case and actual suspension height. For reference, I am running about 5" in the back with a shackle flip and am using 6.5 degrees with 1.5" of T-case drop.
  15. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Appreciate it /forums/images/graemlins/thumb.gif I just wanted simple and after driving it I wanted it done the first time with out dropping my case down . Thanks, but I am stubborn once an idea forms in my thick ole head. Besides I gave up my credit card number and its being built as we speak.
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Really? Where do I find such a tool? I've never seen one at Sears or Home Depot. What does it look like?
  17. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Just make sure to replace the joints in your old shaft and put it in the back for a spare. You will need it eventually. On my first run (the one you were at) I almost needed mine. I have some nice gouges in rear driveshaft already.
