**fixed**quad fire with misfires, need input from yall.
Discussion in 'The Garage' started by bablazer73, Dec 10, 2006.
  1. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    My daughter has a 96 grand am with a quad 4. I am having misfire issues. Snap on scanner shows misfires on cyl 1 and 4, at same times. I have replaced the plugs, connector plugs, distribution box and both coils to no avail!
    Any input? do the injectors fire together ?
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    damn, wish i could be of some help. i had the exact same problem with mine, and it ended up being a bad module. swapped the one from my '95 and it ran fine, put the original back in, and i got misfire codes. not real sure how to diagnose it without throwing parts at it, could be the ECM, or a loose connection. IIRC the injectors do fire at the same time.
  3. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    well, after pulling my freakin hair out with this car, I found the problem!! I started diagnostics from the begining and found the resistance from the coil through the STUPID EFFFIN COIL COVER to be low on cylinders 1 and 4!! Well PISS ME OFF!! thats was a new coil cover!! Replaced part under warranty, all good agian!! Now to re-grow hair??
