Fixed rear yoke on a 208 question.
Discussion in 'The Garage' started by dontoe, Sep 26, 2006.
  1. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    What's the best way to do my rear drive shaft, (with my 208-fixed rear yoke I'm buying), that I can realistically afford?
    Other than going square.
  2. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    duct tape:D
    sorry I had to be a smart ass
  3. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Swap in a 241; you can get a SYE for those pretty readily. Of course, there's the electrical vs mech speedo thing to handle, but I think the shifter might work just fine.
  4. big4x4ride
    big4x4ride 1/2 ton status
    Feb 11, 2004
    216
    Corpus Christi, TX
    i took a dodge case, swapped in the chevy 27 sppline input. used a clockingring from greatlake offroad to get to the position i needed (you have to use this fi dodge case on chevy adapter) and will run flanges front a rear with modifed front chevy shafts on both sides
  5. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
  6. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    I guess I'm horrible at asking questions..............
    What I meant to say is:
    I'm buying a 208 with a fixed rear yoke (dodge parts) from a friend next week, it also has a clocking ring attached!
    My question is:
    What are my options concerning the rear drive shaft. I have a spare front one off a K-10 with a 208 as well as a spare rear off the same truck. Could those be cut up and mated together. And it is a DD as well.
  7. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    You'll be awakened at "da Thump" by the sound of duct tape being wound around yer truck! :D
    Finally removed it and cut the little shield ring off last week. :wink1:
  8. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    have fun drilling and tapping an output shaft. they should be hardened unless you have a faulty one.
  9. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    If you have a lathe it should be no problem . I have a couple at my disposal:D. I was actually thinking about doing this but I am a little wary of any possible post machining issues with the shaft.
    Ira
  10. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    The ouput shaft drills like butter with the correct type drill bits
