fixin a stripped bolt on a NP-205.....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mudrunner78, Apr 8, 2002.
  1. mudrunner78
    mudrunner78 1/2 ton status
    Sep 7, 2001
    366
    Rocksprings, TX
    Ok I messed up good this time, I was replacing my tailshaft on my NP-205 from a slip yoke to a fixed. Well it started to rain so of course I started to hurry. well it seems on of the bolts on the tail shaft was cross threaded and I kept on truning, till the bolt was striped. So now I need to know if its fixable. And how do I fix it? Thanks Jesse
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    A helicoil will fix it good as new.
  3. mudrunner78
    Sep 7, 2001
    366
    Rocksprings, TX
    Not trying to sound to stupid but I thought helicoil's could olny be used in application's that had bottoms. this stripped hole is open on both ends. Again I am just wondering. Also the proper way to install a helicoil if I remember correctly you need a special tool. Thanks Jesse
  4. dyeager535
    26,975
    Use a thread sert. Not sure why anyone uses helicoils anymore with thread-serts available. (no offense) You drill out the hole so you can tap it out to the next size, tap the hole with a STANDARD (not goofy helicoil) tap, then thread the thread-sert in. The ones I pick up at the local non-chain hardware store for about $3 already have loc-tite on them, (to hold the thread sert in place) and I have used them on aluminum thermostat housing bolts that have stripped out, and they haven't leaked in over 4 years
  5. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Thread-serts or weld and re-tap. If you can weld, that is my preferred method, but if not a thread-sert will work just fine. The tail-housings don't have a ton of pull put on them, plus the other bolts should hold it well enough that it won't over stress that one bolt.
  6. mudrunner78
    Sep 7, 2001
    366
    Rocksprings, TX
    thread sert it is not I just have to figure out the size and where they sell them.. Thanks to all Jesse
