Fixing Dry Rot
Discussion in 'The Garage' started by Snowman1000, Mar 16, 2007.
  1. Snowman1000
    Snowman1000 1/2 ton status
    Jan 28, 2007
    518
    Freeland Michigan
    I just got a set of tires and rims and one of the tires is starting to show some signs of dry rot but the tire is still really good real deep tread. Is tubing it an option???
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Unfortunately you have no warning , or estimated time before tread comes off carcass :(
  3. Snowman1000
    Jan 28, 2007
    518
    Freeland Michigan
    So your saying theres nothing I can do:frown1: Becasue I really do not want to have to buy any tires. My uncle was telling me about the goopy black stuff they put over a slice in his tire ( kind of resembled a tar he said) and I guess its working good for him. This truck wouldnt be leaving town much and would rarely reach expressway speeds so would a tube be a viable option
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I wouldn't trust anything short of a new vulcanized tire .
    Whats funny , is it can be 100 degrees out all summer , and our tires don't dry rot if you drive on them often . But you sit a set outside , and they dry rot .
  5. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    the spare seems to do the same thing!
  6. 64suburban
    64suburban Registered Member
    Feb 9, 2006
    57
    tn
    Wow, so true and strange at the same time! Maybe when we drive on the tires they get hot to a certain point and...... I have no Idea?!? That is weird though.
  7. Snowman1000
    Jan 28, 2007
    518
    Freeland Michigan
    Thanks Ill see what I cant scrounge up to replace that tire
  8. sweetk30
    Nov 1, 2004
    25,547
    542
    horseheads , ny 14845
    is it weather checking = fine tiny little cracks
    or
    is it dry rott= deep cracks big ones all the way to the cords.
    let us know or tak a pic and post it up. then link the pic to us here in this thread.
    lots of people miss use the 2 terms.
  9. Snowman1000
    Jan 28, 2007
    518
    Freeland Michigan
    I took pictures but you really cant see the damage to the tire I filled it with air and it leaks in one spot im pretty sure that its dry rotted I put some of that Slime in there it hasnt worked for me yet and I doubt that this will be an exception but what the hell ill give it a try
    The tire seems almost flaky in spots but the rot dosent look to bad just in a few patches.
  10. 91GMCSuburban
    91GMCSuburban 1/2 ton status
    Dec 9, 2002
    318
    San Antonio, TX
    Dry rot doesn't happen to driven tires because the constant rotation pushes the oil base of the tire to the edge of the tire. At least that was what I was told...
  11. Snowman1000
    Jan 28, 2007
    518
    Freeland Michigan
  12. sweetk30
    Nov 1, 2004
    25,547
    542
    def a problem if leaking from side walls. the mud trac tire is still made and sold these days. slime is not going to fix your problem. slime and fix a flat dont walk up the side walls . thay only roll in the tread section.
    you can saw all of this out and get it super clean inside. then go to a good tire shop and buy a radial 31" tube if thats the size you have. i do think its 33 max in radial tube or 35 not sure tho.
    but each choice is up to you. those mud trac tires are hard rubber and do tend to leak down faster than others i have seen over the years.
  13. Snowman1000
    Jan 28, 2007
    518
    Freeland Michigan
    I have alot of good tire shops around the area the tire is a 33. so I would clean the inside of the tire very well, and have a tube put in, and that would be ok. I think I need some further explanation. the rot dosent seem too bad and the whole tire isnt rotted just two small spots about 2 inches around I understand that most tires are readily available but my truck is very rusty and I just cant bring myself to spend an arm and a leg on tires when I only paid 350 for the truck.
