Fixing frame carnage???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KrebsATM02, Aug 30, 2001.
  1. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    Well two weekends ago at the Llano river i managed to rip off my front bumper on one side and crush the frame on the other. Its onlyh screwed up infront of the radiator support, so it doesn't effect anything major. Actually its just kinda twised into an E rather than a C. I'm planning on trying to fix it this weekend so i can put my bumper back on. Any ideas other than a sledge hammer?? Thanks Doug
    Doug Krebs
  2. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Are you planning to use a stock bumper or go with an aftmkt. custom bumper? You can cut it off 4" from the frame damage and weld in or bolt in a donor section from another truck. IF you do want any sort of strength out of this type of setup I would sandwich the frame in between two pieces of 1/4" cold rolled flat stock.
    <a target="_blank" href=http://community.webshots.com/user/thatguydrew23>http://community.webshots.com/user/thatguydrew23</a>
  3. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    What fr8train said is the RIGHT way to fix it. What the heck did ya do to pull the bumper sideways?- Hard pull out of a stuck?
    Stuck is a state of mind!
    Mudstud
    76K5 sb400/350/203parttime/3.73-D44/GM12 locked
  4. KrebsATM02
    Mar 21, 2000
    553
    Oh bye the way it isn't a stock bumper. I was stuck in a very precarious situation. I came down over a ridge and couldn't back up because of property lines. Llano is notorious for tickets, the property owners are out in camo with binoculars waiting for your tire to cross the line. So when i come down over the ridge (due to poor spoting) my front bumper came face to face with a rock. We decided the best thing to do was apply the throttle and hopefully slide up the rock. Well instead of that happening, it twisted and pushed in one side of the frame, and pulled the bracket off the other side. Acted like a lever with a 5500 pound vehicle and gravity on it since i was still on the slope. Oh well any more suggestions other than a better approach angle. Thanks - Doug
    Doug Krebs
