Fixing loose tilt steering...have a qeustion
Discussion in 'The Garage' started by Stickseler, Oct 23, 2004.
  1. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    I needed to fix my loose steering column for inspection, so I got it down to the 4 bolts and got those tightened, but 2 metal shims fell out, one went back under the part that goes from the ignition switch cam to the column bu I can't figure out where the other one came from. Its about a inch long and 3/16 or so wide and its 2 pc ones straight and the other has an arc. Any ideas where it goes, I'm only 2-1/2 hours into a 2 hour project and I'd like to be done by dark /forums/images/graemlins/smile.gif
  2. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
  3. Stickseler
    Mar 23, 2001
    6,503
    Northern Virginia
    My favorite threads?? /forums/images/graemlins/dunno.gif
    I used This one but it dosen't show where all the pieces go
  4. sickquad
    Jul 23, 2003
    785
    Ma
    That's what I meant to post actually, sorry.
  5. dieselandmud
    dieselandmud Registered Member
    Aug 30, 2004
    17
    Cookeville, TN
    Did you figure out where this part goes? I'm in middle of putting the steering colunm back together and the same part pop out and I can't figure out where it goes.
    Thanks in advance
    Chris
