Fixing rust problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlueBlazer, Mar 29, 2001.
  1. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    OK, I just decided I was gettin tired of the rust in my truck. The panel that the bottom of my seatbelts bolt to are gone, I mean they are not there, just the carpet that covers the panel. Also, I took out the carpet and seat out of the back. I found that the floorboard is rusted through right around the body mounts behind the seat. Heres my questions 1) What is the panel the seatbelt bolts to called so I can look it up in LMC or JC Whitney 2) How should I go about fixing the area around the body mounts 3) Is there any shortcuts I can take to fix these problems so I dont have to spend hundreds of dollars on new panels. BTW, Im gonna por 15 everything when Im done to prevent any further rust. Any help is greatly appreciated.
  2. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    Maybe you can find a donor truck or K5. Just cut out the parts you need and weld them in place. Try this web site, www.paddockparts.com. They sell a lot of parts. Too bad your not closer to me. I have a '79 K5 that was in a fire and the panels are still good. Good luck.
  3. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    The same panels went in mine, but I didn't end up finding anyone with replacement panels for the bottom of the B-post. I ended up just fabbing the panels with some sheet steel (3 times as thick!!) and Herculining the inside from firewall to tailgate. Seems to be holding ok 5 mos. later.
    Why do people keep calling it a Bronco!!!!!
  4. BlueBlazer
    Feb 15, 2001
    1,940
    Cmon guys. I know a lot more of you have experienced this and have some great ideas. Again, I appreciate any help you can give me.
