Fixing rust. Replace body mounts first?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Scrubby, Oct 4, 2006.
  1. Scrubby
    Scrubby 1/2 ton status
    Dec 1, 2001
    114
    Boise, ID
    I'm about ready to jump into fixing my rockers, floors, and whatever else I find in there. Would you guys recommend replacing the body mounts and adjusting all the gaps before cutting? Makes sense to me to get it right first. Any comments?
  2. bigdon-70blazer
    bigdon-70blazer Registered Member
    Apr 29, 2006
    38
    Poplar Bluff, MO.
    My body guy wanted the body back on the frame before doing any cutting and replacing of rockers and etc. So I have the body off now and have the frame at the sandblaster so I can repaint it then remount body with the new body mounts then do the body work and paint.
  3. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    its best to have the body mounts fixed first becasue then you can get every thing to line up right if not you will throw off all your work when you do the body mounts later
  4. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    Also, in addition to putting the body on the frame with fresh body mounts (bushings, etc...) you have to make sure you secure the dash/firewall/windshield frame section to the main tub so:
    1) the doors are will properly fit/align/close
    2) the dash/firewall/windshield frame section doesn't fall off/separate from the main tub!
  5. vtblazer
    vtblazer 1/2 ton status GMOTM Winner
    Sep 30, 2003
    2,471
    Central VT
    Make sure to keep the hard top on also!! Very important!
    It will keep the firewall where the firewall needs to be.
  6. bigblock72
    bigblock72 1/2 ton status Premium Member GMOTM Winner
    Oct 18, 2005
    1,235
    59
    American Fork, Utah
    Make darn sure the doors line up properly BEFORE you do any cutting. A lot of times it involves shimming up the front mounts (the front cab mounts) an inch or more, if you plan on running the hard top then make sure it's bolted up securely and fitting correctly. Take measurements on the door openings, the windshield frame etc. Once you cut out the rocker boxes and cab supports there is no structure left and the firewall and windshield frame are free to flop around. Take your time and make sure everything is braced, and don't be afraid to take the doors on and off at every step.
